5赞
350回答
0收藏
[第二轮]看NXP视频,玩盖楼,抢百元话费!
回答|共 350 个
321#
tryramtron
发表于 2013-11-14 10:59:17 | 只看该作者
AC Thyristor Triacs (ACTTs) are a new technology providing the ultimate in over-voltage withstand capability and noise immunity for White Goods and other major appliances. They are intended for highly inductive as well as resistive loads.
主要特性和优势
Full cycle AC conduction
Triggering in three quadrants only
Pin compatible with standard triacs
Safe clamping of low energy over-voltage transients
Protective self turn-on with high energy voltage transients
Clamping structure ensures safe over-voltage withstand capability to IEC 61000-4-5
Sensitive gate for easy logic level triggering
Direct interfacing with low power drivers and microcontrollers
Very high immunity to false turn-on by dV/dt
Planar passivated for voltage ruggedness and reliability
Superior reliability and product quality
主要应用
AC fan, pump and compressor controls
Highly inductive, resistive and safety loads
Large and small appliances (White Goods)
Reversing induction motor controls
Window blind controllers
hhjlele
发表于 2013-11-14 11:46:36 | 只看该作者
NXP可控硅没有用过,这PPT里介绍的封,我们公司也没有用过,如果方便可以来我司推广一下
易冰
发表于 2013-11-14 12:22:39 | 只看该作者
回帖奖励 +10 与非币
白色家电 现在应用到千家万户,征集用户建议对研发很有益吧
彬哥-407895
发表于 2013-11-14 12:32:36 | 只看该作者
这种功率分离器件除了可以运用在家电中,还可以运用在哪里呢?
snowchang_3004195
发表于 2013-11-14 15:18:08 | 只看该作者
回帖奖励 +10 与非币
恩智浦的功率分离器件ACCT很不错。各种电流供选择。
tryramtron
发表于 2013-11-14 15:42:40 | 只看该作者
AC Thyristor Triacs (ACTTs) are full cycle AC conduction power switches with gate triggering in three quadrants only and with self-protection against low and high energy over-voltage transients. Their specially designed structure ensures safe over-voltage withstand capability to IEC 61000-4-5. Protective self turn-on will follow high energy voltage transients, while lower energy transients will be clamped. A choice of gate sensitivities balances high false trigger immunity with ease of triggering. Their planar-passivated construction ensures voltage ruggedness and reliability.
ACTTs are pin compatible with both 3Q Hi-Com and standard 4Q triacs.
ACTT employs our fifth-generation, triple-implanted planar passivated technology. The extra performance and superior reliability of ACTT make it ideally suited to a wide range of applications that contain highly inductive, resistive and safety loads.
shepherd
发表于 2013-11-14 15:46:48 | 只看该作者
抢个楼
xinchao
发表于 2013-11-14 15:49:35 | 只看该作者
回帖奖励 +10 与非币
有点专业,听不大懂,而且讲的声音太小了,听不清。
XinChao
小农
发表于 2013-11-14 15:49:58 | 只看该作者
我来顶上~~~~~
cqzk
发表于 2013-11-14 16:05:13 | 只看该作者
回帖奖励 +10 与非币
已经报名了,期待20元话费。
