查看: 2556|回复: 2
【征集/转载】角蜂鸟AI视觉套件4.ROS下订阅并处理图像
    难过
    2021-2-27 22:16
  • 签到天数: 1568 天
    [LV.Master]伴坛终老
    发表于 2018-8-17 15:40:32 | 显示全部楼层 |阅读模式
    [征集]你玩AI,我送幸运,为AI套件专区添砖加瓦--4角蜂鸟AI视觉套件:(四)ROS下订阅并处理图像
    对于熟悉ROS的朋友们来说,图像的topic有了,我们就可以开始自己想干的事情了。这里我创建一个名为hs_image_sub的package来处理角蜂鸟的图像,图像的topic 名字为上一篇提到的:/hs/camera/image_raw. 也是我们打开rqt_image_view窗口看到的东西。
    这篇博客主要是利用opencv来获取角蜂鸟图像,然后做一个阈值处理,并且打开窗口显示原图和处理后的图像。有了opencv想做什么处理都可以了,这篇文章主要是教大家在ROS里获取并调用图像。
    cd ~/catkin_ws/src
    catkin_create_pkg hs_image_sub roscpp sensor_msgs cv_bridge
    然后
    cd ~/catkin_ws/src/hs_image_sub/src
    touch hs_image_sub_node.cpp
    gedit hs_image_sub_node.cpp
    填入以下代码
    #include <ros/ros.h>
    #include <sensor_msgs/Image.h>
    #include <sensor_msgs/image_encodings.h>
    #include <image_transport/image_transport.h>
    #include <cv_bridge/cv_bridge.h>
    // OpenCV
    #include <opencv2/opencv.hpp>
    #include <opencv2/imgproc/imgproc.hpp>
    #include <opencv2/highgui/highgui.hpp>
    using namespace std;
    using namespace cv;
    const string Original_winName = "Original Image";
    const string Thresh_winName = "Threshed Image";
    Mat cameraFeed;
    Mat HSV;
    Mat threshold_ori;
    void rgbCallback(const sensor_msgs::ImageConstPtr& msg)
        cv_bridge::CvImageConstPtr cv_ptr;
        try
            cv_ptr = cv_bridge::toCvCopy(msg, sensor_msgs::image_encodings::BGR8); // Caution the type here.
        catch (cv_bridge::Exception& ex)
            ROS_ERROR("cv_bridge exception in rgbcallback: %s", ex.what());
            exit(-1);
        cameraFeed = cv_ptr->image.clone();
        cvtColor(cameraFeed,HSV,COLOR_BGR2HSV);
        inRange(HSV,Scalar(0,133,0),Scalar(21,256,256),threshold_ori);
        //show frames
        imshow(Original_winName,cameraFeed);
        imshow(Thresh_winName,threshold_ori);
        //delay 10ms so that screen can refresh.
        //image will not appear without this waitKey() command
        waitKey(10);
    int main(int argc, char *argv[])
        ros::init(argc, argv, "HornedSungemGrabber");
        ros::NodeHandle n;
    //        topic name of HornedSungem
        ros::Subscriber rgb_sub = n.subscribe("/hs/camera/image_raw", 1, rgbCallback);
        ROS_INFO("Subscribe to the HS color image topic.");
        ros::spin();
        return 0;
    代码比较简单,主要是订阅图像源,调用回调函数做阈值处理。
    注意这里的topic name 和回调函数里的格式:BGR8,只能是这个。
    保存,然后
    gedit CMakeLists.txt
    全选,替换为以下内容
    cmake_minimum_required(VERSION 2.8.3)
    project(hs_image_sub)
    find_package(OpenCV REQUIRED)
    find_package(catkin REQUIRED COMPONENTS
      cv_bridge
      roscpp
      sensor_msgs
    catkin_package(
    #  INCLUDE_DIRS include
    #  LIBRARIES hs_image_sub
    #  CATKIN_DEPENDS cv_bridge roscpp sensor_msgs
    #  DEPENDS system_lib
    include_directories(
    # include
      ${catkin_INCLUDE_DIRS}
    add_executable(${PROJECT_NAME}_node src/hs_image_sub_node.cpp)
    target_link_libraries(${PROJECT_NAME}_node
       ${catkin_LIBRARIES} ${OpenCV_LIBS}
    接着编译
    cd ~/catkin_ws
    catkin_make
    看到编译成功,运行角蜂鸟ROS的官方程序,启动相机发布图像源,来供我们这里的程序调用
    roslaunch horned_sungem_launch hs_camera.launch cnn_type:=googlenet camera:=hs pixels:=360
    rosrun hs_image_sub hs_image_sub_node
    有了opencv想做什么处理都可以了比如追踪
    版权声明:本文为博主原创文章,如需转载,请附上文章原文地址。        https://blog.csdn.net/yaked/article/details/81477833
    评分
    参与人数 1与非币 +50 收起 理由
    satoll + 50 AI征集奖励
    查看全部评分
    擦汗
    2024-4-22 16:36
  • 签到天数: 43 天
    [LV.5]常住居民I
    发表于 2018-8-20 09:48:16 | 显示全部楼层
    代码部分排版有问题,请查实
    难过
    2021-2-27 22:16
  • 签到天数: 1568 天
    [LV.Master]伴坛终老
     楼主| 发表于 2018-8-20 22:07:56 | 显示全部楼层
    satoll 发表于 2018-8-20 09:48
    代码部分排版有问题,请查实
    改好了
    GMT+8, 2024-5-8 01:20 , Processed in 0.123945 second(s), 21 queries , MemCache On.
