查看: 1877|回复: 0
MY-IMX6 Linux-4.1.15 编译参考手册(2)
    无聊
    2016-8-19 09:36
    发表于 2019-4-19 17:19:54 | 显示全部楼层 |阅读模式
    【接上一章节MY-IMX6 Linux-4.1.15 编译参考手册(1)】
    3  u-boot编译
    3.1  编译前的准备
    创建编译工作目录
    =====> Input:
    mkdir ~/my-work/02_source/ -p
    解压源码包到工作目录
    =====> Input:
    tar xf u-boot-2016.03-svn*.tar.bz2 -C ~/my-work/02_source/
    3.2  编译u-boot目标文件
    进入源码目录
    =====> Input:
    cd ~/my-work/02_source/u-boot-2016.03
    生成目标开发板的 .config 文件
    =====> Input:
    make myimx6ek140p-6y-256m-emmc_defconfig
    =====> Output:
      HOSTCC  scripts/basic/fixdep
      HOSTCC  scripts/kconfig/conf.o
      SHIPPED scripts/kconfig/zconf.tab.c
      SHIPPED scripts/kconfig/zconf.lex.c
      SHIPPED scripts/kconfig/zconf.hash.c
      HOSTCC  scripts/kconfig/zconf.tab.o
      HOSTLD  scripts/kconfig/conf
    # configuration written to .config
    【注意】:上面 make 后面的 myimx6ek140p-6y-256m-emmc_defconfig 改为与开发板型号对应的配置文件。
    ********** MY-IMX6-EK140 **********
    myimx6ek140-6g-128m-emmc_defconfig  myimx6ek140-6y-128m-emmc_defconfig
    myimx6ek140-6g-128m-nand_defconfig  myimx6ek140-6y-128m-nand_defconfig
    myimx6ek140-6g-256m-emmc_defconfig  myimx6ek140-6y-256m-emmc_defconfig
    myimx6ek140-6g-256m-nand_defconfig  myimx6ek140-6y-256m-nand_defconfig
    myimx6ek140-6g-512m-emmc_defconfig  myimx6ek140-6y-512m-emmc_defconfig
    myimx6ek140-6g-512m-nand_defconfig  myimx6ek140-6y-512m-nand_defconfig
    ********** MY-IMX6-EK140P **********
    myimx6ek140p-6g-128m-emmc_defconfig  myimx6ek140p-6y-128m-emmc_defconfig
    myimx6ek140p-6g-128m-nand_defconfig  myimx6ek140p-6y-128m-nand_defconfig
    myimx6ek140p-6g-256m-emmc_defconfig  myimx6ek140p-6y-256m-emmc_defconfig
    myimx6ek140p-6g-256m-nand_defconfig  myimx6ek140p-6y-256m-nand_defconfig
    myimx6ek140p-6g-512m-emmc_defconfig  myimx6ek140p-6y-512m-emmc_defconfig
    myimx6ek140p-6g-512m-nand_defconfig  myimx6ek140p-6y-512m-nand_defconfig
    ********** MY-IMX6-EK200 **********
    myimx6ek200-6q-1g_defconfig     myimx6ek200-6q-2g_defconfig     myimx6ek200-6q-512m_defconfig
    myimx6ek200-6u-1g_defconfig     myimx6ek200-6u-2g_defconfig     myimx6ek200-6u-512m_defconfig
    myimx6ek200-6s-512m_defconfig   myimx6ek200-6s-1g_defconfig     myimx6ek200-6s-128m_defconfig
    myimx6ek200-6qp-1g_defconfig    myimx6ek200-6qp-2g_defconfig    myimx6ek200-6qp-512m_defconfig
    ********** MY-IMX6-EK314 **********
    myimx6ek314-6q-1g_defconfig     myimx6ek314-6q-2g_defconfig     myimx6ek314-6q-512m_defconfig
    myimx6ek314-6u-1g_defconfig     myimx6ek314-6u-2g_defconfig     myimx6ek314-6u-512m_defconfig
    myimx6ek314-6s-512m_defconfig   myimx6ek314-6s-1g_defconfig     myimx6ek314-6s-128m_defconfig
    myimx6ek314-6qp-1g_defconfig    myimx6ek314-6qp-2g_defconfig    myimx6ek314-6qp-512m_defconfig
    ********** MY-IMX6-EK336 **********
    myimx6ek336-6q-1g_defconfig     myimx6ek336-6q-2g_defconfig     myimx6ek336-6q-512m_defconfig
    执行编译
    =====> Input:
    make
    =====> Output:
    scripts/kconfig/conf  --silentoldconfig Kconfig
      CHK     include/config.h
      UPD     include/config.h
      GEN     include/autoconf.mk
      GEN     include/autoconf.mk.dep
      CHK     include/config/uboot.release
      CHK     include/generated/timestamp_autogenerated.h
      CFG     u-boot.cfg
      LD      u-boot
      OBJCOPY u-boot-nodtb.bin
      OBJCOPY u-boot.srec
      SYM     u-boot.sym
      COPY    u-boot.bin
      CFGS    board/myzr/myimx6/myimx6a7-6y-ddr3.cfg.cfgtmp
      MKIMAGE u-boot.imx
    Note: 如果有提示 “cc1: error”,通常是交叉编译工具的配置没生效,可以按前面 “交叉编译工具链安装” 中的 “source 工具链配置文件” 操作一次后再执行此步骤。
    u-boot 目标文件
    u-boot.imx 即目标文件。
    3.3  编译u-boot环境变量脚本
    =====> Input:
    mkimage -A arm -O linux -T script -C none -a 0 -e 0 -n "myzr bootscripts" -d board/myzr/bootscripts/myimx6a7_l4115_emmc_script.cmd my_environment_emmc.scr
    =====> Output:
    Image Name:   myzr bootscripts
    Created:      Wed Jan  2 09:40:40 2019
    Image Type:   ARM Linux Script (uncompressed)
    Data Size:    1450 Bytes = 1.42 kB = 0.00 MB
    Load Address: 00000000
    Entry Point:  00000000
    Contents:
    Image 0: 1442 Bytes = 1.41 kB = 0.00 MB
    3.4  目标文件
    u-boot.imx 和 my_environment_emmc.scr 即编译得到的目标文件,保存这两个文件
    4  内核编译
    4.1  编译前的准备
    创建编译工作目录
    =====> Input:
    解压源码包到工作目录
    =====> Input:
    tar xf linux-4.1.15-svn*.tar.bz2 -C ~/my-work/02_source/
    4.2  编译内核目标文件
    进入内核源码目录
    =====> Input:
    cd ~/my-work/02_source/linux-4.1.15
    生成目标平台的 .config 文件
    =====> Input:
    make myimx6a9_defconfig
    =====> Output:
    Note: 如果有“Can't find default configuration "arch/x86/configs” 的错误,是因为交叉编译工具链的配置没有生效,可以按前面 “交叉编译工具链安装” 中的 “source 工具链配置文件” 操作一次后再执行此步骤
    【注意】:上面 make 后面的 myimx6a7_defconfig 改为与开发板型号对应的配置文件。
    ********** MY-IMX6-EK140、MY-IMX6-EK140P **********
    myimx6a7_defconfig
    ********** MY-IMX6-EK200、MY-IMX6-EK314、MY-IMX6-EK336 **********
    myimx6a9_defconfig
    编译内核目标文件
    =====> Input:
    make zImage
    =====> Output:
      CHK     include/config/kernel.release
      UPD     include/config/kernel.release
      WRAP    arch/arm/include/generated/asm/auxvec.h
      AS      arch/arm/boot/compressed/piggy.lzo.o
      LD      arch/arm/boot/compressed/vmlinux
      OBJCOPY arch/arm/boot/zImage
      Kernel: arch/arm/boot/zImage is ready
    内核目标文件
    arch/arm/boot/zImage 即内核目标文件
    【下章节为MY-IMX6 Linux-4.1.15 编译参考手册(3)】
    GMT+8, 2024-5-6 14:07 , Processed in 0.129818 second(s), 18 queries , MemCache On.
