查看: 1273|回复: 0
MY-IMX6-EK200 Linux-4.1.15 测试手册(3)
    无聊
    2016-8-19 09:36
    发表于 2019-4-25 10:39:22 | 显示全部楼层 |阅读模式
    【接上一章节MY-IMX6-EK200 Linux-4.1.15 测试手册(2)】
    10.2  ECSPI2 测试
    位置:J7: 8,10
    测试设备:/dev/spidev1.0
    测试指令
    # /my-demo/linux-4.1.15/MY_SPIDEV_TEST_L4115_MYIMX6A9.out -D /dev/spidev1.0
    spi mode: 0
    bits per word: 8
    max speed: 500000 Hz (500 KHz)
    FF FF FF FF FF FF
    40 00 00 00 00 95
    FF FF FF FF FF FF
    FF FF FF FF FF FF
    FF FF FF FF FF FF
    DE AD BE EF BA AD
    F0 0D
    11  Watchdog 测试
    11.1  超时复位测试
    # /unit_tests/wdt_driver_test.out 10 15 1
    Starting wdt_driver (timeout: 10, sleep: 15, test: write)
    Trying to set timeout value=10 seconds
    The actual timeout was set to 10 seconds
    Now reading back -- The timeout is 10 seconds
    U-Boot 2016.03-svn270 (Oct 09 2018 - 14:44:15 +0800)
    CPU:   Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz)
    CPU:   Extended Commercial temperature grade (-20C to 105C) at 45C
    Reset cause: WDOG
    Board: MYZR i.MX6 Evaluation Kit
    11.2  喂狗测试
    # /unit_tests/wdt_driver_test.out 4 2 1 &
    [1] 748
    Starting wdt_driver (timeout: 4, sleep: 2, test: write)
    Trying to set timeout value=4 seconds
    The actual timeout was set to 4 seconds
    Now reading back -- The timeout is 4 seconds
    12  RTC 测试
    查看当前系统时钟
    # date
    Wed Sep 26 00:27:45 UTC 2018
    查看当前RTC芯片时钟
    # hwclock
    Wed Sep 26 00:28:01 2018  0.000000 seconds
    设置系统时钟,并同步到RTC芯片
    # date -s "2018-09-21 12:34:56"
    Fri Sep 21 12:34:56 UTC 2018
    将系统时钟写入硬件时钟
    # hwclock -w
    断电重启评估板
    查看当前系统时钟
    # date
    Fri Sep 21 12:36:11 UTC 2018
    查看当前RTC芯片时钟
    # hwclock
    Fri Sep 21 12:36:16 2018  0.000000 seconds
    13  定时唤醒测试
    设定 10 秒后产生唤醒事件
    # echo +10 > /sys/class/rtc/rtc1/wakealarm
    使设备进入
    # echo mem > /sys/power/state
    睡眠信息
    PM: Syncing filesystems ... done.
    Freezing user space processes ... (elapsed 0.001 seconds) done.
    Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
    Suspending console(s) (use no_console_suspend to debug)
    PM: suspend of devices complete after 59.213 msecs
    PM: suspend devices took 0.060 seconds
    PM: late suspend of devices complete after 1.004 msecs
    PM: noirq suspend of devices complete after 1.031 msecs
    Disabling non-boot CPUs ...
    CPU1: shutdown
    CPU2: shutdown
    CPU3: shutdown
    Enabling non-boot CPUs ...
    CPU1 is up
    CPU2 is up
    CPU3 is up
    PM: noirq resume of devices complete after 1.138 msecs
    PM: early resume of devices complete after 1.136 msecs
    PM: resume of devices complete after 116.878 msecs
    PM: resume devices took 0.120 seconds
    Restarting tasks ... done.
    唤醒信息
    (elapsed 0.012 seconds) done.
    PM: suspend of devices complete after 693.963 msecs
    PM: suspend devices took 0.700 seconds
    PM: late suspend of devices complete after 2.419 msecs
    PM: noirq suspend of devices complete after 2.303 msecs
    PM: noirq resume of devices complete after 1.402 msecs
    PM: early resume of devices complete after 1.476 msecs
    PM: resume of devices complete after 121.763 msecs
    PM: resume devices took 0.130 seconds
    14  音频测试
    14.1  播放音频
    # aplay /unit_tests/audio8k16S.wav
    Playing WAVE '/unit_tests/audio8k16S.wav' : Signed 16 bit Little Endian, Rate 8000 Hz, Stereo
    14.2  音频录音
    录音
    # arecord -d 5 -f S16_LE -t wav foobar.wav
    播放录音
    # aplay foobar.wav
    15  显示屏(选配)测试
    特别说明:
         U-Boot 版本u-boot-2016.03 svn315及以上
         内核 版本  linux-3.0.35  svn31及以上
                    linux-3.14.52 svn369及以上
                    linux-3.14.52 svn368及以上
         烧录工具   MfgTool-MYIMX6A9-L* svn181及以上
    请参考《MY-IMX6-A9系列:显示功能测试》进行测试
    一般情况下则按照如下方法测试
    在系统启动过程中,可以看到 Linux 小企鹅和 OpenEmbedded 启动画面。
    【下章节为MY-IMX6-EK200 Linux-4.1.15 测试手册(4)】
    GMT+8, 2024-5-2 13:40 , Processed in 0.136713 second(s), 18 queries , MemCache On.
