Virtex-4 RocketIO ML423 特性描述平台
#板卡评测
1324 人阅读
0 人回复
2012-07-23
TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
状元
- 积分
- 3075
Xilinx ML423 platform is ideal for characterization and evaluation of Virtex®-4 FX RocketIO MGT Transceivers. Each RocketIO™ MGT Transceiver is accessible via 4 SMA connectors. ML423 platform is populated with FX100-FF1152 FPGA device. 其中包含:
- Virtex-4 FX RocketIO characterization platform (referred to as the ML42x platform)
- User guide
- Six SMA-to-SMA cable assemblies
- System ACE CompactFlash memory card
- Power supply module
- SuperClock module
- Power supply
- Development tools and PC download cable are not included and must be ordered separately
- SMA wrench
关键特性
- Virtex-4 FPGA (referred to as the device under test, or DUT, in user guide)
- Onboard power supplies for all necessary voltages capable of supplying 1.5A to 6A
- Power supply jacks for optional use of external power supplies
- JTAG configuration port for use with Parallel Cable III and Parallel Cable IV cables
- System ACE™ configuration controller
- RS-232 serial port
- MGT power supply module for supporting all transceiver power requirements
- Two 2.5V/3.3V global clock oscillator sockets
- Two single-ended global clock inputs with SMA connectors
- Two differential global clock inputs with SMA connectors
- Xilinx Generic Interface (XGI)
- SuperClock module with XGI
- 24 or 96 pairs of SMA connectors for the RocketIO transceivers
- Power indicator LEDs
- General purpose DIP switches, LEDs, and pushbuttons
- One differential local clock input with SMAs
- Four differential MGT clock inputs with SMAs
- EU-RoHS compliant
