TA的每日心情 | 开心 2013-9-2 09:06 |
签到天数: 11 天 连续签到: 1 天 [LV.3]偶尔看看II
Altera FPGA 组件为高端视讯应用(DVI & HDMI)理想之影像处理平台。友晶科技在高阶影像、图像、网络和多媒体领域的专业设计,提供全球知名大厂多样影像产品。友晶科技研发的 Cyclone III FPGA 影像开发套件(包含 Cyclone III FPGA 开发平台和支持分辨率高达 1600 x 1200的高端 DVI 板卡)附有完整的 DVI 视讯控制器设计与程序代码;使用者亦可运用本开发系统体验高阶的影像处理设计 VIP (Altera 影像与图像处理Mega Core套件)。Altera Cyclone III Development Board
Cyclone III development board (DK-DEV-3C120N)Cyclone III EP3C120F780 Development boardEmbedded USB-Blaster circuitry (includes an Altera MAX II CPLD) - allowing download of FPGA configuration files via the flash device or the host computerMemory256 Mbytes of dual-channel DDR2 SDRAM with ECC8 Mbytes of synchronous SRAM64 Mbytes of flashCommunication ports10/100/1000 EthernetUSB 2.0Power and analog devicesSwitching power supplySwitching and step-down regulatorsAnalog to digital converterLDO regulatorsClocking50-MHz and 125-MHz on-board oscillatorsSMA inputs/outputsInputs/outputs for the two HSMC connectorsVarious buttons, switches, and indicatorsDisplay128 x 64 graphics LCD2-line x 16-character LCDConnectorsTwo HSMCsUSB type BDebug toolsThree HSMC debug cards (two loop-back and a debug header)Cables and power/analog14-V–20-V DC inputOn-board power measurement circuitry19.8 W per HSMC interfacePower cord with plug adapters (US, UK, EU)Cyclone III FPGA Development Kit, CD-ROMDesign examples for the Cyclone III FPGA development boardComplete documentationUser guideReference manualBoard schematic and layoutBill of materialsProduct and partner informationAltera Complete Design Suite DVDQuartus® II design softwareSubscription Edition (optional feature, available for purchase)Web Edition (no charge, Windows only)ModelSim®-Altera softwareAltera Edition (optional feature, available for purchase)Web Edition (no charge, Windows only)MegaCore® IP Library - OpenCore Plus evaluationIncludes Nios II processor (evaluation license)Nios II Embedded Design Suite, Evaluation Edition (no charge)DSP Builder (optional feature, available for purchase)Video demos of Quartus II software and Nios II embedded processorDVI-HSMC CardDigital TransmitterOne DVI transmitter with single transmitting portDigital Visual Interface (DVI) CompliantSupports resolutions from VGA to UXGA (25 MHz – 165 MHz Pixel Rates)Universal Graphics Controller Interface12-Bit, Dual-Edge and 24-Bit, Single-Edge Input ModesAdjustable 1.1 V to 1.8 V and Standard 3.3 V CMOS Input Signal LevelsFully Differential and Single-Ended Input Clocking ModesStandard Intel 12-Bit Digital Video Port Compatible as on Intel™ 81x ChipsetsEnhanced PLL Noise ImmunityOn-Chip Regulators and Bypass Capacitors for Reducing System CostsEnhanced Jitter PerformanceNo HSYNC Jitter AnomalyNegligible Data-Dependent JitterProgrammable Using I²C Serial InterfaceSingle 3.3-V Supply OperationDigital ReceiverOne DVI receiver with sinle receiving portSupports UXGA Resolution (Output Pixel Rates Up to 165 MHz)Digital Visual Interface (DVI) Specification CompliantTrue-Color, 24 Bit/Pixel, 16.7M Colors at 1 or 2-Pixels Per ClockLaser Trimmed Internal termination Resistors for Optimum Fixed Impedance Matching4x Over-SamplingReduced Ground Bounce Using Time Staggered Pixel OutputsLowest Noise and Best Power Dissipation Using TI PowerPAD™ PackagingCyclone III 影像开发平台组件配置
