描述
eZ430-F2013是一个完整的MSP430 开发工具,包括在USB记忆棒里评估MSP430F2013和开发一个完整项目的所有硬件和软件。该 eZ430-F2013 支持 Code Composer Studio 和 IAR Embedded WorkbenchIntegrated Development Environments,来提供单机设计的完整的仿真,或者拆解可拆卸的板卡来融合到现有设计中。该USB端口提供了足够的电源来运行超低功耗的,所以不提供外部电源供电。The ECCN (Export Control Classification Number) classification for this tool will be the same as the included microcontrollers. To find ECCN information for a microcontroller, see the datasheet for that device.Any use made of Texas Instruments (TI) classifications, whether it be ECCNs or HTS, is without recourse to TI and at the user’s risk. HTS and export classifications are subject to change. Your company, as the exporter of record, is responsible for determining the correct classification of any item at the time of export. Any HTS or export classification by TI is for TI’s internal use only and shall not be construed as a representation or warranty regarding the proper export classification nor relied upon to make licensing determinations.
特性
- eZ430-F2013 development tool including a USB debugging interface and detachableMSP430F2013 target board
- eZ430-F2013 target board
- LED indicator
- 14 user accessible pins
- eZ430 debugging and programming interface
- Supports development with some 2xx Spy Bi-Wire devices (refer to Table 1-1 in MSP430 Hardware Tools User's Guide for complete compatibility list)
- Supports eZ430-T2012 and eZ430-RF2500T target boards
- Removable USB stick enclosure
- Includes IAR Kickstart and Code Composer Studio which include an assembler, linker, source-level debugger and limited C-compiler
- Full documentation on CD-ROM
包含项目
- CD-ROM including software and documentation
- IAR Embedded Workbench (Kickstart Version) IDE
- eZ430-F2013 Development Tool
下载连接:
eZ430-F2013 开发工具用户指南 |
