回答
收藏
MSP430 无线开发工具
#板卡评测 #板卡评测 1171 人阅读 | 0 人回复 | 2012-08-02
描述
eZ430-RF2500是用于MSP430 和CC2500的完整无线开发工具,包含所有硬件和软件,在USB棒里开发含MSP430的整个无线项目。该工具包含一个USB供电的仿真器,用来在系统里编程和调试你的应用。 还有两个2.4-GHz 无线目标板突出了 高度集成的 MSP430F2274 超低功耗 MCU.Projects may be developed and instantly deployed using the included battery expansion board and AAA batteries. All the required software is included such as a complete Integrated Development Environment and SimpliciTI, a propriety low-power star network stack, enabling robust wireless networks out of the box. The eZ430-RF2500 uses the MSP430F22x4 which combines 16-MIPS performance with a 200-ksps 10-bit ADC and 2 op-amps and is paired with the CC2500 multi-channel RF transceiver designed for low-power wireless applications.The eZ430-RF emulator interface may be used with any Spy Bi-Wire enabled MSP430, such as the F22xx and F20xx series, and is fully compatible with the eZ430-F2013 and eZ430-T2012 target boards. The emulator interface can be used to download and debug your target applications, and can transmit serial data to your PC while in or out of a debug session.The ECCN (Export Control Classification Number) classification for this tool will be the same as the included microcontrollers. To find ECCN information for a microcontroller, see the datasheet for that device.Any use made of Texas Instruments (TI) classifications, whether it be ECCNs or HTS, is without recourse to TI and at the user’s risk. HTS and export classifications are subject to change. Your company, as the exporter of record, is responsible for determining the correct classification of any item at the time of export. Any HTS or export classification by TI is for TI’s internal use only and shall not be construed as a representation or warranty regarding the proper export classification nor relied upon to make licensing determinations.
 特性
  • CC2500 - 2.4 GHz, ISM band multi-channel low power transceiver
  • 2 LEDs
  • 1 pushbutton
  • Supports development with some 2xx Spy Bi-Wire devices (refer to Table 1-1 in MSP430 Hardware Tools User's Guide for complete compatibility list)
  • Supports MSP430 Application UART allowing serial communication to PC
  • Supports eZ430-T2012 and eZ430-RF2500T target boards
  • Removable USB stick enclosure
  • SimpliciTI, low power network stack
  • Example wireless sensor network project measuring temperature, voltage and signal strength
包含项目
  • SLAC063, Code Composer Essentials v3.1 SR1 Core Edition - Free 16KB IDE
  • SLAC139, eZ430-RF2500 Sensor Monitor Demo
  • SLAU144, MSP430x2xx Family User's Guide
  • SLAC050, IAR Embedded Workbench KickStart (IAR 5.40.7 / WIN, FET 6.12 / WIN)
  • MSP430F2274 – 32KB Flash, 1KB RAM, 1 USCI (UART, (2) SPI, I2C, IrDA), 10-bit 200 ksps, 2 Op Amps
  • One AAA battery pack with expansion board (batteries included)
  • One MSP430 Development Tool CD-ROM containing documentation and new development software for eZ430-RF2500
  • One eZ430-RF USB debugging interface
  • Two eZ430-RF2500T wireless target boards
下载连接:
eZ430-RF2500 开发工具用户指南
