MSP430F51x2/MSP430F51x1 40 引脚 RSB 目标板
#板卡评测
1504 人阅读
0 人回复
2012-08-03
描述
MSP-TS430RSB40是独立的 40引脚 ZIF 插座目标板,用于通过 JTAG 接口或者 Spy Bi-Wire (2-wire JTAG) 协议对 MSP430 系统内置器件进行编程和调试.该开发板支持采用 40 引脚 QFN 封装(TI 封装代码:RHA)的所有 MSP430F51x2 和MSP430F51x1 闪存部件。(TI 封装代码: RSB). What's Included:
- Development board with 40-pin QFN (RSB) ZIF socket (MSP-TS430RSB40)
- JTAG Header cable
- Two MSP430F5172RSB Silicon devices
- One READ ME FIRST document
- Micro Crystal MS3V-T1R 32.768kHz
The ECCN (Export Control Classification Number) classification for this tool will be the same as the included microcontrollers. To find ECCN information for a microcontroller, see the datasheet for that device.Any use made of Texas Instruments (TI) classifications, whether it be ECCNs or HTS, is without recourse to TI and at the user’s risk. HTS and export classifications are subject to change. Your company, as the exporter of record, is responsible for determining the correct classification of any item at the time of export. Any HTS or export classification by TI is for TI’s internal use only and shall not be construed as a representation or warranty regarding the proper export classification nor relied upon to make licensing determinations.
特性
- Development board (MSP-TS430RSB40) with a 40-pin ZIF socket fitting MSP430 derivatives in 40-pin QFN (RSB) packages includes an LED indicator, JTAG adapter, and header pin-outs for prototyping
- Supports all debugging interfaces using a standard 14-pin JTAG header such as the MSP-FET430UIF.
下载连接:
MSP430硬件工具用户指南
用于MSP430的IAR嵌入式工作平台用户指南
MSP430 硬件工具 |
