回答
收藏
MCB2470 评估板
#板卡评测 #板卡评测 1314 人阅读 | 0 人回复 | 2012-08-03
Keil MCB2470评估板让您编写和测试用于NXP公司LPC2470 ARM系列的芯片应用程序。MCB2470评估板拥有NXP LPC2478 MCU的特色,如触摸屏3.2" 色的QVGA LCD显示接口、USB (Host & OTG)、CAN、 Ethernet、SD/MMC cards和UARTs。MCB2470 Features
  • LPC2478 ARM7TDMI processor-based MCU
  • On-Chip Memory: 512KB Flash & 96KB RAM
  • External Memory: 128MB NAND Flash, 4MB NOR Flash, & 32MB SDRAM
  • Color QVGA LCD with Touchscreen
  • 10/100 Ethernet Port
  • USB 2.0 Full Speed - USB, USB-OTG, USB Host, & UART via USB
  • Serial Port and CAN Interface
  • SD/MMC Card Interface
  • 5-position Joystick and 3-axis accelerometer
  • Analog Voltage Control for ADC Input
  • Amplifier and Speaker
  • JTAG interface and ETM Trace port (provision for a Mictor-38 connector)
Components Included
The MCB2470 Evaluation Board includes the following:
  • MCB2470 Evaluation Board,
  • QVGA LCD and Touch Screen,
The QVGA module included with the MCB2470 board is a 320x240 Color LCD display with Touchscreen capabilities. It is permanently mounted to the MCB2470 base board.
  • MCB2470 Quick Start Guide,
  • MDK-ARM Evaluation Tools.
System Requirements
  • PC with one available USB port,
  • Windows 2000, XP and Vista,
  • One CD-ROM drive,
  • ULINK family USB-JTAG Adapter for high-performance Debug/Download (optional).
Starter Kit
The MCB2470 is also available as a starter kit which includes the ULINK2 USB-JTAG adapter.Part numbers are:
  • MCB2470: MCB2470 Only
  • MCB2470U: MCB2470 and ULINK2
Evaluation Software
The MCB2470 Evaluation Board and Starter Kit include the MDK-ARM Evaluation Tools. These tools help you get started writing programs and testing the microcontroller and its capabilities. Sample applications that run on the MCB2470 are included.
下载连接:
MCB2470评估板快速入门指南
MCB2470评估板电路原理图
MCB2470评估板OEM电路原理图
3075 积分
915 主题
+ 关注
