回答
收藏
MSP430F5xx 100 引脚目标板
#板卡评测 #板卡评测 1370 人阅读 | 0 人回复 | 2012-08-03
描述
MSP-TS430PZ5x100 是独立的 ZIF 插座目标板,它用于通过 JTAG 接口或 Spy Bi-Wire(2 线 JTAG)协议对 MSP430 系统内置器件进行编程和调试。该开发板支持采用 100 引脚 LQFP 封装(TI 封装代码:PZ)的所有 MSP430F5xx 闪存部件。A flash emulation tool (FET) may be purchased independently (MSP-FET430UIF) or bundled with a target board (MSP-FET430U5x100).The ECCN (Export Control Classification Number) classification for this tool will be the same as the included microcontrollers. To find ECCN information for a microcontroller, see the datasheet for that device.Any use made of Texas Instruments (TI) classifications, whether it be ECCNs or HTS, is without recourse to TI and at the user’s risk. HTS and export classifications are subject to change. Your company, as the exporter of record, is responsible for determining the correct classification of any item at the time of export. Any HTS or export classification by TI is for TI’s internal use only and shall not be construed as a representation or warranty regarding the proper export classification nor relied upon to make licensing determinations.
特性
  • Supports all debugging interfaces using a standard 14-pin JTAG header such as the MSP-FET430UIF
包含项目
  • Development board (MSP-TS430PZ5x100) with a ZIF socket fitting MSP430F5xx derivatives in 100-pin TQFP (PZ) packages includes an LED indicator, JTAG adapter, and header pin-outs for prototyping
  • Eight PCB 1x25-pin headers (four male and four female)
  • MSP430 Flash Device: MSP430F5438IPZ
  • One 32.768-kHz crystal
  • One MSP430 CD-ROM
  • One READ ME FIRST document
下载连接:
MSP430硬件工具用户指南
用于MSP430的IAR嵌入式工作平台用户指南
MSP430 硬件工具
