Stellaris 评估套件提供了提供了一个低成本且有效的评估Stellaris 系列微控制器的途径。评估板的核心是独立的工具和 独立的Stellaris 系列器件。For kit-specific documentation and software, please refer to the individual kit links in the table below: 特性
LM3S9D92 Evaluation Kits (EK-LM3S9D92)
EKK-LM3S9D92
EKI-LM3S9D92
EKC-LM3S9D92
EKT-LM3S9D92
EKS-LM3S9D92
Keil Tools
IAR Tools
CodeSourcery Tools
Code Red Technologies Tools
Code Composer Studio Tools
Features an evaluation version of the Keil RealView Microcontroller Development Kit software tool.
Features the IAR Embedded Workbench-KickStart edition, a 32 KB-limited evaluation version of the IAR Embedded Workbench.
Features a 30-day evaluation version of CodeSourcery's SourceryG++ professional-quality GNU tool chain including optimized drivers for debug through serial wire debug.
Features a 60-day evaluation version of Code Red Technologies tools.
Features a board-locked, fully functional version of Code Composer Studio (CCStudio) Integrated Development Environment (IDE).
Kit Overview
The Stellaris® LM3S9D92 Ethernet+USB-OTG Evaluation Kit provides a low-cost evaluation platform for the LM3S9D92 ARM® Cortex-M3-based microcontroller. The kit includes two boards: the EK-LM3S9D92 evaluation board and an In-Circuit Debug Interface (ICDI) board. The evaluation board features a simple, streamlined design for 32-bit Stellaris-based application with industrial connectivity, highlighting the Stellaris LM3S9D92 microcontroller's simultaneous integrated 10/100 Ethernet MAC/PHY, full-speed USB-OTG interfaces, and convenient connection to the MCU's GPIO ports. The kit features:
Small form factor - just 36mm x 102mm
The Stellaris LM3S9D92 high-performance microcontroller with large memory
32-bit ARM® Cortex-M3 core
512 KB main Flash memory, 96 KB SRAM, and ROM loaded with StellarisWare® software
Integrated 10/100 Ethernet MAC/PHY, USB OTG, CAN, and Motion Control IP
Ethernet 10/100 port with two LED indicators
USB 2.0 Full-Speed OTG port
Virtual serial communications port capability
Oversized board pads for GPIO access
Reset pushbutton and power LED
User pushbutton and LED
Detachable In-Circuit Debug Interface (ICDI) board can be used for programming and debugging other Luminary Micro boards
