回答
收藏
PIC32 多媒体扩展板
#板卡评测 #板卡评测 686 人阅读 | 0 人回复 | 2012-08-13
多媒体扩展板 (MEB) 为发展高影响力的用户界面提供了 PIC32 初学者工具包、 dsPIC33E USB 初学者工具包或 PIC24E USB 初学者工具包用户综合而灵活的使用解决方案。主板附带了 3.2 彩色 TFT 触摸屏 QVGA 显示,板载 FCC 认证 WiFi 模块、 24 位立体声音频编码、 三维加速度计、 游戏杆和一个 MicroSD 记忆卡插槽。Simply connect any DM320001, DM320003-2, DM320004, DM330012 and DM240012 Starter Kit to the MEB and you're ready to develop, program and debug code for the user interface features. Demo software for the MEB may be downloaded below and is also contained within the Microchip Application Library, including software for the joystick, accelerometer, CPLD and more.Box Contents: Multimedia Expansion Board(MEB) Information Sheet with links to get started directing users to web based instructions for software download and installation. Note that no software is provided in the box.Note: Microchip MPLAB C Compiler Evaluation Versions are free! They are full-featured for the first 60 days. After 60 days only optimization level 1 can be enabled in the compiler.Board Features:1. 3.2 inch (8.1 cm) QVGA touch screen display with backlight 2. Five user-controlled LEDs3. Four-way joystick (S2)4. Fire button (S1)5. Headphone jack6. Line output jack7. Microphone input jack8. Power LED9. PICtail™ compatible expansion connector1. Solomon Systech Graphics Controller (SSD1926)2. microSD card slot.3. Regulated 3.3V and 1.8V power supply for powering the board via a starter kit or 9-14V power supply4. Accelerometer and temperature sensor (BMA150)5. 24LC08 EEPROM.6. SPI Flash (SST25VF016)7. 24-bit audio codec (WM8731)8. CPLD for SPI and Chip Select configuration9. Starter kit connector10. Integrated 802.11 wireless connectivity
下载连接:
多媒体扩展板简介
多媒体扩展板用户指南
3075 积分
915 主题
+ 关注
