回答
收藏
PIC24H MCUs MPLAB入门套件
#板卡评测 #板卡评测 515 人阅读 | 0 人回复 | 2012-08-13
MPLAB PIC24H MCUs 入门工具包对于开发探索 MCU PIC24H系列的多任务需要功能是一个完整的硬件和软件。With a built-in debugger on the board, simply install the software and connect the USB cable to the PC. Start up MPLAB IDE and gain full control. Run the accelerometer based sample programs and check out the interaction of the accelerometer and the switches with the MCU on the visual display and listen to the speech playback. Connect your own analog sensor for sensor signal processing. Download and test your own applications.The starter kit features PIC24HJ128GP504 MCU with 128 KB Flash and 8 KB RAM as the computational unit. A tri-axial accelerometer is provided for acceleration detection. The starter kit also showcases a low cost audio playback with an on-board speaker and an OLED display running Microchip Graphics library. A separate signal conditioning circuit is provided to plug-in a wide range of sensors.Features
  • Board includes integrated debugger / programmer
  • USB powered
  • PIC24HJ128GP504 MCU with 128 KB Flash and 8 KB RAM
  • Features a tri-axial analog accelerometer, 128x64 OLED display, on-board speaker
  • Low cost speech play back of G.711 compressed speech
  • Visual display on OLED display using Microchip Graphics library
  • Switches for application utility
  • Separate analog conditioning circuitry to plug-in wide range of sensors for sensor signal processing
  • CD contains MPLAB IDE with full editor, programmer and debugger; MPLAB C Compiler; code examples and user’s guide
下载连接:
PIC24H MCUs MPLAB入门套件用户指南
