回答
收藏
DLP LightCrafter智能高速图形显示器
#板卡评测 #板卡评测 905 人阅读 | 0 人回复 | 2012-08-14
描述
DLP LightCrafter是一个紧凑的评估模块,用于将方案整合到工业、医疗和科学应用上。This DLP-based platform enables faster development cycles for end equipments requiring small form factor, lower cost and intelligent, high-speed pattern display. DLP LightCrafter features the 0.3 WVGA chipset, provides a variety of embedded functionality such as: structured light pattern projection, intelligent lighting, wavelength selection and portable display.Developers can easily create, store, and display high-speed pattern sequences through DLP LightCrafter's USB-based application programming interface (API) and easy-to-use graphical user interface (GUI). The module also features the powerful TMS320DM365 digital media processor based on DaVinci technology from Texas Instruments. With an ARM9 DSP core, DLP LightCrafter's DM365 runs a Linux operating system to give users the ability to develop a complete embedded system around the 0.3 WVGA chipset. A configurable input/output trigger allows for convenient synchronization with cameras, sensors, or other peripheral devices.The DLP LightCrafter includes an RGB LED light engine developed and manufactured by Young Optics International. Designed specifically for the DLP3000 DMD, this light engine produces bright, wide aspect ratio patterns well-suited for use in a variety of ambient light environments. For applications where even higher brightness is required, active cooling and thermal management systems can be added to enable light out in excess of 50 lumens.Included with DLP LightCrafter Development Module:
  • DLP 0.3 WVGA chipset
  • RGB LED light engine
  • DMD controller board
  • Processor and interface board
  • Embedded Linux OS
Cables and power supply sold separately. Order power supply here.
特性
  • RGB LED light engine with 20L light output
  • High speed patterns using the native DLP3000 resolution (608 x 684)
    • Up to 4000 Hz binary pattern rate
    • Up to 120 Hz 8-bit grayscale pattern rate
  • Display images or video up to WVGA resolution (854 x 480)
  • Configurable I/O trigger for synchronizing with cameras, sensors, etc
  • DM365 embedded processor running embedded Linux
  • 128MB NAND flash memory for pattern and sequence storage
  • USB, Mini HDMI, UART interfaces
  • USB-based API and host GUI
  • Compact size: 117mm x 65mm x 23mm
包含项目
  • DLPR300, DLPC300 配置和支持固件
  • DLP3000-C300REF, DLP 0.3 WVGA 芯片组参考设计
  • TMS320DM365, 数字媒体片上系统 (DMSoC)
  • DLPC300, 0.3 WVGA 数字控制器
  • DLP3000, DLP 0.3 WVGA DMD
可用更新
The software and firmware provides developers flexibility and advanced control of the digital micromiror device (DMD). In addition, it offers convenient interfacing and extensive feature sets to accelerate development of end equipments using spatial light modulation. DLP LightCrafter EVMs come installed with Firmware and Software Package v1.0. To promote proper functionality, do not combine software and firmware from different release packages.The firmware and software packages include:DLPLIGHTCRAFTERGUI – Graphical user interface enables easy configuration of and data upload to DLP LightCrafter™via the USB. API commands can be sent from Windows, Linux, and Mac machines (Windows only in v1.0 package). GUI v3.8 is only compatible with DLP LightCrafter modules that have upgraded to Firmware and Software Package v1.1. GUI v3.7 should be used with un-upgraded DLP LightCrafter modules out-of-box.DLPR300FPGA – Configuration firmware for optional FPGA. Programs an Altera Cyclone IV EP4CE6 FPGA that can be used in conjunction with the DLPC300 controller to enable even higher speed monochrome pattern display on the DLP3000 compared with using the DLPC300 alone. The optional FPGA allows users to multiplex two data input sources and provides a fully configurable I/O trigger for synchronizing cameras, sensors, and other peripheral devices. It also provides for additional LED control capabilities.DLP3000-C300REFDM365 - Application reference SW based on TI's DVSDK platform. Includes Linux kernel, Linux filesystem, Linux product support package (PSP), application framework (APIs), codec libraries (MPEG4,H.264, MPEG2, G.711, JPEG), example programs, DSP Codegen, and CodeSourcery tool chain with IDE for cross-compiling and debugging target systems.DLP3000-C300REFMSP - Application reference SW for system initialization & shutdown, LED driver control, and power supply sequencing.DLP3000-C300REFEDID - Extended display identification data stored in EDID PROM configures system to accept video input through HDMI port at WVGA (864x480) or native DLP3000 (608x684) resolutions.
下载连接:
DLP LightCrafter开发套件用户指南
