回答
收藏
DM642 评估模块
#板卡评测 #板卡评测 1022 人阅读 | 0 人回复 | 2012-08-14
描述
DM642评估模块是一个廉价的高性能视频&图像开发平台,用于快速开始应用开发和评估多通道、多格式数字和其他未来应用。Leveraging the high performance TMS320C64x DSP core, this development platform supports TI’s TMS320DM642, DM641 & DM640 digital media processors.Developed in conjunction with Spectrum Digital, this PCI form factor EVM includes the necessary components to enable you to:
  • Start application software development immediately
  • Understand DSP functionality for video experts
  • Build video, audio & internet streaming functionality into existing designs
  • Simplify overall system design
  • Differentiate your product with cutting edge software
  • Design for flexibility to respond to evolving standards
Supported by award winning eXpressDSP host tools and target software, users have the unique ability to quickly and easily integrate eXpressDSP-compliant algorithms from over one hundred TI third parties into the included starterware to accelerate completion of your evaluation and development of digital media solutions.For users who require a more comprehensive development kit including a complete set ofeXpressDSP host development tools and target software, an XDS560 high speed advanced emulator, camera and cables, please see the DM64x Digital Media Developer’s Kit for more information.The software included with the EVM allows you to seamlessly jump-start development. The Device Driver Kit (DDK) provides customers with ready to use DSP/BIOS device drivers for TI DSP peripherals and working examples to develop your own device drivers.Initial low-level design decisions are eliminated when using the eXpressDSP Reference Framework5 (RF5) because it provides a getting started solution in the early stages of application development. This easy-to-use source code is common to many applications. RF5 is designed to handle anywhere from 1 to 100+ channels of data, and from 1 to 100+ different algorithms. It makes maximal use of several of the advanced DSP/BIOS capabilities such as the task module (TSK) and semaphore module (SEM). This allows truly dynamic, multi-channel, multi-rate operation where any channel can block any other channel. Streams like audio and video can easily be mixed together.Source code is available for Video Application demos for Composite/S-Video In/Out, Capture/Display pass-thru, On-Screen Display (OSD) and Audio Loopback, while object code libraries are included for Streaming Media executable demos such as Video Loopback (H.263, MPEG-2 video and JPEG), TCP/IP Networking stack (Client Configuration), Network camera and Audio Loopback (G.729).The full contents of the kit include:
  • DM642 EVM Baseboard
  • DM642 EVM CD (contents described above)
  • DM642 EVM Quick Start Guide
  • DM642 EVM technical reference
  • 5V/5A Power Supply
  • Multilingual Regulatory Compliance Statement
Ordering Information:TMDSEVM642 includes a standard US power cordTMDSEVM642-0E version includes a European power cord
特性
DM642 EVM Hardware features:DSP & Memory
  • 720 Mhz DM642 DSP
  • 4 MBytes Flash, 32 MB of 133 MHz SDRAM and 256 kbit I2C EEPROM
Video Capture
  • 3 Female RCA connectors for composite video input (NTSC, PAL)
  • 1 Female S-Video connector for component (Y-C) video input (NTSC, PAL)
Video Display
  • TVP5150/5146 Video Decoder
  • 3 Female RCA connectors (1 for composite video output, and 3 for RGB output or HDTV)
  • 1 Female S-Video connector for RGB monitor output
  • 1 Female 15-pin VGA connector for RGB monitor output
  • On-Screen Display support (OSD FPGA)
Audio
  • 2 Channel Line In (stereo), 8kHz to 96 kHz sampling rate
  • 2 Channel Line Out (stereo)
  • 1 Microphone Input (mono)
Connectivity
  • Can be used as a PCI plug-in card or stand-alone with an external power supply brick (+5V)
  • 10BASE-T or 100 Base-TX using single RJ-45 connector
  • Dual UART interface
  • Daughter card interface for video port and memory bus expansion
Emulation, Power, Miscellaneous
  • 14-pin JTAG for external emulation hardware support
  • 60-pin next generation emulation header for advanced emulation features such as Trace and High Speed Real-Time Data Exchange
  • Boot mode selection via switches
  • Push button reset
  • 8 User defined LEDs and GPIOs
  • On-board switching voltage regulators for adjustable DSP core voltage (+1.2 to +1.4) and fixed +1.8V (OSD FPGA) and +3.3V
DM642 EVM Software:
  • Installation support for CCStudio v2.2 and v3.0.
  • DM642 Chip Support Package, DSP/BIOS kernel support for the new peripherals (Video Port, VIC, EMAC, MDIO)
  • Device Driver Kit (DDK), which includes drivers for DM642 video capture and display drivers for the DM642 EVM card, AIC23 audio codec driver, Dual UART driver, Generic McASP data mover driver for C64x DSPs, and PCI target-side driver from Valley Technologies.
  • eXpressDSP Reference Framework 5
  • Video Application Demos including source code for: Capture/Display Pass-thru Demos (Composite/S-Video In/Out), On-Screen Display (OSD), Audio Loopback
  • Streaming Media Executable Demos (with object code libraries) Video Loopback demos
  • (H.263, MPEG-2 video and JPEG), TCP/IP Networking stack (Client/Configuration), Network Camera Demo and Audio Loopback (G.729)
下载连接:
DM642 驱动实例
