回答
收藏
dsPICDEM MC1电机控制开发板
#板卡评测 #板卡评测 1084 人阅读 | 0 人回复 | 2012-08-15
电机控制开发系统向设计者提供了三个主要组成部分的应用,快速验证了BLDC,PMAC和ACIM的应用。The three main components are: dsPICDEM™ MC1 Motor Control Development Board, dsPICDEM MC1L 3-Phase Low Voltage Power Module and dsPICDEM MC1H 3-Phase High Voltage Power Module.The dsPICDEM MC1 Motor Control Development Board contains the dsPIC30F6010 but supports all dsPIC® Digital Signal Controller (DSC) motor control variances, various peripheral interfaces and a custom interface header system, which allows different motor power modules to be connected to the PCB. The control board also has connectors for mechanical position sensors, such as incremental rotary encoders and hall effect sensors, and a breadboard area for custom circuits. The main control board receives its power from a standard plug-in transformer.The dsPICDEM MC1L 3-Phase Low Voltage Power Module is optimized for 3-phase motor applications that require a DC bus voltage less than 50 volts and can deliver up to 400W power output. The 3-phase low voltage power module is intended to power BLDC and PMAC motors.The dsPICDEM MC1H 3-Phase High Voltage Power Module is optimized for 3-phase motor applications that require DC bus voltages up to 400 volts and can deliver up to 1 kW power output. The high voltage module has an active power factor correction circuit that is controlled by the dsPIC30F device. This power module is intended for AC induction motor and power inverter applications that operate directly from the AC line voltage.Two motors are available that are compatible with the development system.特性:
Features of the dsPICDEM MC1 Motor Control Development Board are:• dsPIC30F6010 Motor Control MCU Based BoardThe optional power modules provide:• Heat sink for Ambient Cooling of Power Sections• Full Automatic Protection of Power Circuits• Electrical Isolation from Power CircuitsPackage Contents (Power Modules)• High Voltage or Low Voltage Power Module• Example Software and Documentation on CDPackage Contents(Motor Control Development Board)• dsPICDEM MC1 Motor Control Development Board with Pre-programmed dsPIC30F Device• RS-232 Cable• Power Supply• Example Software and Documentation on CD• Many Options for Motor Feedback Signals
下载连接:
dsPICDEM MC1机电控制开发板用户指南
