回答
收藏
以太网PICtail Plus子板
#板卡评测 #板卡评测 663 人阅读 | 0 人回复 | 2012-08-16
以太网PICtail™ Plus子板提供了评估和开发以太网控制应用的一个经济高效的方案。The board is designed for flexibility and can be plugged into Microchip’s Explorer 16 (DM240001) development boards. The development board is populated with Microchip’s 28-Pin ENC28J60 Ethernet controller which interfaces to the RJ-45 female connector. When used in conjunction with the Microchip TCP/IP stack (free download below) the Ethernet PICtail Plus daughter board allows a developer to connect any Microchip 16-bit product to the Ethernet.特性:
  • IEEE 802.3 Compliant
  • 10BASE-T Ethernet
  • RJ-45 Female Ethernet Connector
  • Plug in compatible with the Explorer 16 Development Board
下载连接:
以太网PICtail Plus子板简介
