查看: 1038|回复: 0
东芝TB6064AH的替换驱动芯片
  • 签到天数: 2 天
    发表于 2022-10-18 09:51:47 | 显示全部楼层 |阅读模式
    TB67S128HG
    CLOCK-in controlled Bipolar Stepping Motor Driver
    1. Outline
    The TB67S128HG is a PWM controlled two-phase bipolar stepping motor driver
    with an integrated clock-in decoder.
    Fabricated with the BiCD process, the output rating is 50V/5.0A
    (Motor supply voltage = 44 V).
    2. Features
    BiCD process integrated monolithic IC
    Capable of controlling 1 bipolar stepping motor.
    PWM controlled constant-current drive
    Low on-resistance (High + Low side = 0.25 Ω (typ.))
    MOSFET output stage
    Weight: 7.6 g (typ.)
    Allows 1/1, 1/2, 1/4, 1/8, 1/16, 1/32, 1/64, and 1/128 step operation.
    Constant current PWM control (Mixed Decay)
    Integrated current sensing (ACDS: Advanced Current Detection System)
    High voltage and current (for specification, please refer to absolute maximum ratings and operating ranges)
    Multiple error detections (Thermal shutdown (TSD), Over current (ISD), and Power-on-reset (POR)).
    Built-in VCC regulator for internal circuit
    Adjustable PWM chopping frequency with external resistance and capacitor.
    TB67S128HG: HZIP25-P-1.00F package
    Note: Please be careful about thermal conditions during using.
    GMT+8, 2024-5-7 11:35 , Processed in 0.123323 second(s), 15 queries , MemCache On.
