查看: 11176|回复: 7
[群150178878]我也来发个改写的nRF51822的Printf函数,轻量版
发表于 2014-5-23 10:32:28 | 显示全部楼层 |阅读模式
打印格式是 %s %d %c %x %d, 调试的时候特别好用。源码放在附件, 直接替换就能使用
#include <stdint.h>
#include "nrf.h"
#include "simple_uart.h"
#include "nrf_delay.h"
#include "nrf_gpio.h"
#define UART_DEBUG 1
uint8_t simple_uart_get(void)
  while (NRF_UART0->EVENTS_RXDRDY != 1)
    // Wait for RXD data to be received
  NRF_UART0->EVENTS_RXDRDY = 0;
  return (uint8_t)NRF_UART0->RXD;
bool simple_uart_get_with_timeout(int32_t timeout_ms, uint8_t *rx_data)
  bool ret = true;
    if (timeout_ms-- >= 0)
      // wait in 1ms chunk before checking for status
      nrf_delay_us(1000);
    else
      ret = false;
      break;
  }  // Wait for RXD data to be received
  if (timeout_ms >= 0)
    // clear the event and set rx_data with received byte
      *rx_data = (uint8_t)NRF_UART0->RXD;
  return ret;
void simple_uart_put(uint8_t cr)
  NRF_UART0->TXD = (uint8_t)cr;
  while (NRF_UART0->EVENTS_TXDRDY!=1)
    // Wait for TXD data to be sent
  NRF_UART0->EVENTS_TXDRDY=0;
void simple_uart_putstring(char *str)
#if UART_DEBUG
  uint_fast8_t i = 0;
  uint8_t ch = str[i++];
  while (ch != '\0')
    simple_uart_put(ch);
    ch = str[i++];
#endif
void simple_uart_config(  uint8_t rts_pin_number,
                          uint8_t txd_pin_number,
                          uint8_t cts_pin_number,
                          uint8_t rxd_pin_number,
                          bool    hwfc)
/** @snippet [Configure UART RX and TX pin] */
  nrf_gpio_cfg_output(txd_pin_number);
  nrf_gpio_cfg_input(rxd_pin_number, NRF_GPIO_PIN_NOPULL);
  NRF_UART0->PSELTXD = txd_pin_number;
  NRF_UART0->PSELRXD = rxd_pin_number;
  if (hwfc)
    nrf_gpio_cfg_output(rts_pin_number);
    nrf_gpio_cfg_input(cts_pin_number, NRF_GPIO_PIN_NOPULL);
    NRF_UART0->PSELCTS = cts_pin_number;
    NRF_UART0->PSELRTS = rts_pin_number;
    NRF_UART0->CONFIG  = (UART_CONFIG_HWFC_Enabled << UART_CONFIG_HWFC_Pos);
  NRF_UART0->BAUDRATE         = (UART_BAUDRATE_BAUDRATE_Baud9600 << UART_BAUDRATE_BAUDRATE_Pos);
  NRF_UART0->ENABLE           = (UART_ENABLE_ENABLE_Enabled << UART_ENABLE_ENABLE_Pos);
  NRF_UART0->TASKS_STARTTX    = 1;
  NRF_UART0->TASKS_STARTRX    = 1;
void simple_uart_printHEX(uint32_t value)
#if UART_DEBUG
        const uint8_t ASCII[16] = {'0', '1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E', 'F'};
        if(value <= 0xFF)
                simple_uart_put('0');
                simple_uart_put('x');
                simple_uart_put(ASCII[value>>4]);
                simple_uart_put(ASCII[value & 0x0f]);
        else if(value <= 0xFFFF)
                simple_uart_put(ASCII[(value>>12) & 0xf]);
                simple_uart_put(ASCII[(value>>8) & 0xf]);
                simple_uart_put(ASCII[(value>>4 ) & 0xf]);
        else if(value <= 0xFFFFFF)
                simple_uart_put(ASCII[(value>>20) & 0xf]);
                simple_uart_put(ASCII[(value>>16) & 0xf]);
                simple_uart_put(ASCII[(value>>8 ) & 0xf]);
        else if(value <= 0xFFFFFFFF)
                simple_uart_put(ASCII[(value>>28) & 0xf]);
                simple_uart_put(ASCII[(value>>24) & 0xf]);
        simple_uart_put('\r');
        simple_uart_put('\n');
#endif
void simple_uart_print(char *str, uint8_t newline)
#if UART_DEBUG
        simple_uart_putstring(str);
#endif
// µÝ¹éµ÷Óà just for simple_uart_printf
static void printn(unsigned int n, unsigned int b)
        static char *ntab = "0123456789ABCDEF";
        unsigned int a, m;
        if (n / b)
                a = n / b;
                printn(a, b);
        m = n % b;
        simple_uart_put(ntab[m]);
void simple_uart_printf(char *fmt, ...)
#if UART_DEBUG
    char c;
    unsigned int *adx = (unsigned int*)(void*)&fmt + 1;
_loop:
    while((c = *fmt++) != '%')
        if (c == '\0') return;
        simple_uart_put(c);
    c = *fmt++;
    if (c == 'd' || c == 'l')
        printn(*adx, 10);     //print HEX value
    if (c == 'o')
        printn(*adx, 8);
        if(c == 'x')
                printn(*adx, 16);
    if (c == 's')
                simple_uart_putstring((char*)*adx);
    if (c == 'c')
        simple_uart_put(*adx);
    adx++;
goto _loop;
#endif
simple_uart.c.TXT
5.28 KB, 下载次数: 102
simple_uart.h.TXT
2.65 KB, 下载次数: 71
    慵懒
    2015-8-5 08:38
  • 签到天数: 12 天
    发表于 2014-5-26 10:25:04 | 显示全部楼层
    学习一下!
  • 签到天数: 6 天
    发表于 2014-5-29 08:29:17 | 显示全部楼层
    赞赞!!!!!
    发表于 2014-7-25 22:27:42 | 显示全部楼层
    谢谢分享,学习
  • 签到天数: 26 天
    [LV.4]偶尔看看III
    发表于 2014-12-3 00:46:27 | 显示全部楼层
    貌似不能显示负数?
    发表于 2015-1-6 15:52:01 | 显示全部楼层
    学习,学习。。。。
    发表于 2017-1-5 19:46:17 | 显示全部楼层
    谢谢,看看呢
    发表于 2017-6-14 09:57:14 | 显示全部楼层
    谢谢分享
    谢谢,看看呢
    GMT+8, 2024-5-5 22:01 , Processed in 0.183806 second(s), 30 queries , MemCache On.
