查看: 1701|回复: 0
[教程] 【一网打尽】Raspberry Pi Course Week 4 – Day 2 (Basic Commands)
  • 签到天数: 242 天
    发表于 2015-3-28 12:45:08 | 显示全部楼层 |阅读模式
    The following is a basic that the terminal will pass to the operating system and perform the action.  Commands can also use flags in the form of – followed by a letter.  This extends the capability of the command.
    Enter the following command.
    $ ls
    This will list any files in the current directory. These commands can be extended by using flags.  A flag is an additional option to the command which allows it to perform additional functions.  For example enter the following.
    $ ls -F
    /Desktop             /Downloads       /Music                  MyTextFile.txt                  MyProgram.py
    The forward slash at the beginning of the file indicates that this is a folder. Desktop, Downloads & Music are all folders but MyTextFile.txt and MyProgram.py are files.
    $ ls -l
    This flag will list the files in a longer format which include the permissions for the files, who owns the file and the date that it was created.  Permissions are indicated by the
    drwxr-xr-x
    Permission will be explained later along with file ownership.  You can also combine flags to give you additional results.  Enter the following.
    $ ls -lF
    This will list the files in long format and will also display the forward slash / to indicate folders.
    You can use the following flags to display more information.
    -d        list the name of the current directory
    -F        show directories with a trailing ‘/’
      -a        List the hidden files.
    -g        show group ownership of file in long listing
    -l        Displays details in a long format about files and directories.
    -t        Sort by time modified.
    -R        Displays all subdirectories.
    -i        print the inode number of each file
    To expand on what you have already learned enter the following command.
    $ clear
    This command will clear the terminal window and the date command will display the current date.  Enter the command.
    $ date
    Enter the following command to display some information about the system.
    $ uname -a
    Another great little feature of the terminal is its history.  By pressing the up arrow key, it will allow you to browse the commands that you have previously entered.
    GMT+8, 2024-4-29 00:19 , Processed in 0.118708 second(s), 15 queries , MemCache On.
