查看: 2559|回复: 0
[教程] 【一网打尽】LEARN RASPBERRY PI (13 of 13)
  • 签到天数: 242 天
    发表于 2015-3-30 22:13:12 | 显示全部楼层 |阅读模式
    Overview SIMON MONK
    The Raspberry Pi can make a great home automation controller. But to be really useful, it needs to be able to turn electrical appliances and lights on and off. That means it needs to be able to control 110V safely.
    In this lesson, you will combine the PIR sensor from Lesson 12 with the Powerswitch Tail 2 module from Adafruit, to automatically switch something on when movement is detected.
    Parts SIMON MONK
    To build the project described in this lesson, you will need the following parts.
    PIR Sensor
    Power Switch Tail 2
    Pi Cobbler
    Half-size Breadboard
    Raspberry Pi
    Jumper wire pack
    Hardware SIMON MONK
    The Powerswitch Tail 2 from Adafruit, looks like a 110V electrical lead with a box in the middle.
    If you have 220V mains, this tutorial wont work for you - If we knew of an equivalent 220V controller like the PST we would have a link to it here
    The box is actually an opto-isolated solid-state relay. The opto-ilsolation bit means that there is no actual electrical connection between the low voltage switching circuit and the 100V mains. This makes it extremely safe and removes any chance of accidentally frying your Pi.
    What is more the control input consumes just 3 mA of current at 3.3V, which means we can control it directly from one of the Pi's output pins.
    The PIR sensor is connected to a different pin from lesson 12, so be sure to move the yellow lead.
    The Powerswitch Tail comes with a little indicator LED that shows when it is on, so you do not need to connect anything high voltage to it yet.
    Software SIMON MONK
    This project is possible the most over-engineered automatic light switch ever created. You really do not need a Raspberry Pi to turn on the Powerswitch, but the example can easily be adapted for other purposes. For example, you could use a combination of temperature, humidity, light, and perhaps some internet data on weather forecasts to turn on or off a heater, fan or humidifier.
    Copy Code
    • import time
    • import RPi.GPIO as io
    • io.setmode(io.BCM)
    • pir_pin = 24
    • power_pin = 23
    • io.setup(pir_pin, io.IN)
    • io.setup(power_pin, io.OUT)
    • io.output(power_pin, False)
    • while True:
    •     if io.input(pir_pin):
    •         print("POWER ON")
    •         io.output(power_pin, True)
    •         time.sleep(20);
    •         print("POWER OFF")
    •         time.sleep(5)
    •     time.sleep(1)
    The program first sets up the two GPIO pins that are used, one as an input to the PIR sensor and one as an output for the Powerswitch Tail.
    The main loop then just waits for the PIR sensor to sense movement and then prints a message and turns on the Powerswitch tail, waits 20 seconds then turns it off again.
    It the output was turned on, it waits for 5 seconds to prevent immediate retriggering.
    There is also always a 1 seconds delay each time around the loop.
    Configure and Test SIMON MONK
    There are lots of ways to get the sketch from the listing below onto your Raspberry Pi. Perhaps the easiest is to connect to your Pi using SSH (See Lesson 6) opening an editor using the command below:
    Copy Code
    • nano powerswitch.py
    and then pasting in the code , before saving the files using CTRL-x.
    To start with, cover the PIR sensor with something, so that it is not activated until you are ready.
    Run the program as superuser using the command:
    Copy Code
    • sudo python powerswitch.py
    Uncover the PIR sensor and you should see a message saying 'POWER ON' and the little LED on the Powerswitch Tail should light, then turn itself off after 20 seconds.
    Now this is all working, you can try attaching a lamp or some electrical appliance to the Powerswitch Tail.
    Do not write code that turns the power on and off very rapidly. Many kinds of appliance, including lamps will be damaged by high frequency switching. This type of setup should turn things on for a few seconds minimum.
    GMT+8, 2024-5-9 02:22 , Processed in 0.124731 second(s), 16 queries , MemCache On.
