2回答
0收藏
【Fireblue】之四--proxr协议之简易的蓝牙防丢器
其他 其他 7296 人阅读 | 2 人回复 | 2015-07-09
简易的蓝牙防丢器,最主要是采用了proxr的协议,主要实现的功能有:
未连接状态下:发出广播或者关闭广播。
连接状态下:
未超出预设范围安静工作,不报警不闪烁。
超出预设范围报警并且闪烁。
未超出预设范围,手机主动呼叫报警,寻找物品所在位置。
为超出预设范围,防丢器主动呼叫手机,确定手机位置。
断开状态下:如果丢失物品信号出现重新连接。
程序设计:
proxr为标准的蓝牙协议,在源代码中已经实现,只需添加proxr协议的实现代码(proxr.c,proxr.h,proxr_task.c,proxr_task.h,app_proxr.c,app_proxr.h,app_proxr_task.c,app_proxr_task.h)打开proxr的宏配置即可开启proxr协议,
程序架构图
proxr 初始化:
void proxr_init(void)
    // Reset Environment
    memset(&proxr_env, 0, sizeof(proxr_env));
    // Register PROXR task into kernel
    task_proxr_desc_register();
    ke_state_set(TASK_PROXR, PROXR_DISABLED);
void proxr_alert_start(uint8_t lvl, uint8_t char_code)
    // Allocate the alert value change indication
   struct proxr_alert_ind *ind = KE_MSG_ALLOC(PROXR_ALERT_IND,
                                              proxr_env.con_info.appid, TASK_PROXR,
                                              proxr_alert_ind);
   // Fill in the parameter structure
   memcpy(&ind->conhdl, &proxr_env.con_info.conhdl, sizeof(uint16_t));
   ind->alert_lvl = lvl;
   ind->char_code = char_code;
   // Send the message
   ke_msg_send(ind);
void proxr_disable(void)
    atts_size_t length;
    uint8_t *alert_lvl;
    // Disable LLS in database
    attsdb_svc_set_permission(proxr_env.lls_shdl, PERM_RIGHT_DISABLE);
    // If IAS is supported
    if (proxr_env.ias_shdl != ATT_INVALID_HANDLE)
        // Disable IAS in database
        attsdb_svc_set_permission(proxr_env.ias_shdl, PERM_RIGHT_DISABLE);
    // If TXPS is supported
    if (proxr_env.txps_shdl != ATT_INVALID_HANDLE)
        // Disable TXPS in database
        attsdb_svc_set_permission(proxr_env.txps_shdl, PERM_RIGHT_DISABLE);
    struct proxr_disable_ind *ind = KE_MSG_ALLOC(PROXR_DISABLE_IND,
                                                 proxr_disable_ind);
    //Get Alert Level value stored in DB
    attsdb_att_get_value(proxr_env.lls_shdl + LLS_IDX_ALERT_LVL_VAL,
                         &length, &alert_lvl);
    ind->conhdl            = proxr_env.con_info.conhdl;
    ind->lls_alert_lvl    = *alert_lvl;
    // Send the message
    ke_msg_send(ind);
    // Go to idle state
    ke_state_set(TASK_PROXR, PROXR_IDLE);
proxr任务说明,省去程序内容,只列举函数名和函数参数:
处理PROXR_CREATE_DB_REQ 消息,
* @brief Handles reception of the @ref PROXR_CREATE_DB_REQ message.
* The handler adds LLS and optionally TXPS into the database.
* @param[in] msgid Id of the message received (probably unused).
* @param[in] param Pointer to the parameters of the message.
* @param[in] dest_id ID of the receiving task instance (probably unused).
* @param[in] src_id ID of the sending task instance.
* @return If the message was consumed or not.
static int proxr_create_db_req_handler(ke_msg_id_t const msgid,
                                       struct proxr_create_db_req const *param,
                                       ke_task_id_t const dest_id,
                                       ke_task_id_t const src_id)
说明:在连接之后,使能Proximity 报告角色
* @brief Enable the Proximity Reporter role, used after connection.
* @param[in] msgid     Id of the message received.
static int proxr_enable_req_handler(ke_msg_id_t const msgid,
                                    struct proxr_enable_req const *param,
说明:处理接收到的GATT_WRITE_CMD_IND 消息
* @brief Handles reception of the @ref GATT_WRITE_CMD_IND message.
* The handler will analyse what has been set and decide alert level
static int gatt_write_cmd_ind_handler(ke_msg_id_t const msgid,
                                      struct gatt_write_cmd_ind const *param,
说明:断开连接
* @brief Disconnection indication to proximity reporter.
* Alert according to LLS alert level.
static int gap_discon_cmp_evt_handler(ke_msg_id_t const msgid,
                                        struct gap_discon_cmp_evt const *param,
我的其他帖子:
3.【Fireblue】之三---官方测试程序安装和连接https://www.cirmall.com/bbs/thread-42376-1-2.html
2.【Fireblue】之二---git同步代码https://www.cirmall.com/bbs/forum ... =42373&fromuid=8155
1.【Fireblue】之一---首贴开箱照 https://www.cirmall.com/bbs/forum ... =42371&fromuid=8155
回答|共 2 个
奋斗哥
发表于 2015-7-10 08:41:29 | 只看该作者
多谢楼主分享!
suoma
发表于 2015-10-1 10:23:11 | 只看该作者
可以双向防丢吗?即智能手机如果丢失,则利用防丢器的及时报警功能可以迅速查找到,如果防丢器设备丢失,利用智能手机也可以实现查找
