查看: 2573|回复: 5
[讨论] Tiva C练手
  • 签到天数: 1313 天
    连续签到: 3 天
    发表于 2015-12-4 18:38:38 | 显示全部楼层 |阅读模式
    源代码:
    // Software License Agreement
    // Texas Instruments (TI) is supplying this software for use solely and
    // exclusively on TI's microcontroller products. The software is owned by
    // TI and/or its suppliers, and is protected under applicable copyright
    // laws. You may not combine this software with "viral" open-source
    // software in order to form a larger program.
    // THIS SOFTWARE IS PROVIDED "AS IS" AND WITH ALL FAULTS.
    // NO WARRANTIES, WHETHER EXPRESS, IMPLIED OR STATUTORY, INCLUDING, BUT
    // NOT LIMITED TO, IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
    // A PARTICULAR PURPOSE APPLY TO THIS SOFTWARE. TI SHALL NOT, UNDER ANY
    // CIRCUMSTANCES, BE LIABLE FOR SPECIAL, INCIDENTAL, OR CONSEQUENTIAL
    // DAMAGES, FOR ANY REASON WHATSOEVER.
    // This is part of revision 2.1.1.71 of the EK-TM4C123GXL Firmware Package.
    #include <stdint.h>
    #include "inc/tm4c123gh6pm.h"
    //! \addtogroup example_list
    //! <h1>Blinky (blinky)</h1>
    //! A very simple example that blinks the on-board LED using direct register
    //! access.
    // Blink the on-board LED.
    int
    main(void)
        volatile uint32_t ui32Loop;
        // Enable the GPIO port that is used for the on-board LED.
        SYSCTL_RCGC2_R = SYSCTL_RCGC2_GPIOF;
        // Do a dummy read to insert a few cycles after enabling the peripheral.
        ui32Loop = SYSCTL_RCGC2_R;
        // Enable the GPIO pin for the LED (PF3).  Set the direction as output, and
        // enable the GPIO pin for digital function.
        GPIO_PORTF_DIR_R = 0x08;
        GPIO_PORTF_DEN_R = 0x08;
        // Loop forever.
        while(1)
            // Turn on the LED.
            GPIO_PORTF_DATA_R |= 0x08;
            // Delay for a bit.
            for(ui32Loop = 0; ui32Loop < 200000; ui32Loop++)
            // Turn off the LED.
            GPIO_PORTF_DATA_R &= ~(0x08);
            // Delay for a bit.
    慵懒
    2018-3-28 17:24
  • 签到天数: 276 天
    发表于 2015-12-4 19:57:55 | 显示全部楼层
    好像素
  • 签到天数: 868 天
    发表于 2015-12-4 22:04:16 | 显示全部楼层
    这图也太清晰了吧
  • 签到天数: 1617 天
    [LV.Master]伴坛终老
    发表于 2015-12-5 07:36:26 | 显示全部楼层
    的确看不清。
  • 签到天数: 222 天
    [LV.7]常住居民III
    发表于 2015-12-5 09:31:52 | 显示全部楼层
    看不清~~~~
  • 签到天数: 1313 天
    连续签到: 3 天
     楼主| 发表于 2015-12-5 09:57:51 | 显示全部楼层
    晚上拍的。
    GMT+8, 2024-5-16 02:11 , Processed in 0.157089 second(s), 26 queries , MemCache On.
