查看: 2743|回复: 2
[EVAL-WSN]传感器篇——ADT75温度传感器
  • 签到天数: 971 天
    发表于 2015-12-20 11:02:30 | 显示全部楼层 |阅读模式
           ADT75 是一款 精度±2.0°C(−25℃至+100°C),分辨率0.0625°C/LSB  12位数字温度传感器 SMBus/I2C总线
            注意点:
           1)1条SMBus/I2C总线最多挂8个ADT75       2)ADT75温度值寄存器是左对齐的,这有利于数据的处理,由12位二进制补码字表示。MSB是温度符号 位。四个LSB(位DB0至DB3)不是温度转换结果的一部分, 始终为0。也就是说读出来,就是有符号的16位
    ADSENSORAPP_RESULT_TYPE Get_Temp_From_ADT75()
        uint16_t Data;
        ADSENSORAPP_RESULT_TYPE result;
        result = adsAPI_I2C_Reg_Write_Byte(ADT75_DEV_ADDR, ADT75_ONESHOT_REG_ADDR, ADT75_ONESHOT_REG_DEFVAL);       //One-Shot Mode
        //adsAPI_Delay(ADI_Sensor_Delay);
        result = adsAPI_I2C_Reg_Read_Word(ADT75_DEV_ADDR, ADT75_TEMPVAL_REG_ADDR, &Data, 0);
        if(result == API_FAIL)
            SensData.ADT75 = 0;
        else {
            #if 0
            //Data = 0xE700;  //-25
            Data = Data >> 4;
            if (Data >> 11)
                SensData.ADT75 = (((float)Data) - 4096)/16;
            else
                SensData.ADT75 = ((float) Data)/16;
            #else
            SensData.ADT75 = ((float)((int16_t)Data/16) )/16;
            #endif
        return result;
            3)初始化
            ADT75 只有四个寄存器
    依次配置 Thyst  Tos  配置寄存器,即可
    ADSENSORAPP_RESULT_TYPE ADT75_Config_for_Intr()
        uint8_t status = 0;
    //=========================== Program Critical Temperature Registers to raise interrupt ======================================//
        /*设置超过高温 OS/ALERT引脚激活*/
        status = adsAPI_I2C_Reg_Write_Word(ADT75_DEV_ADDR, ADT75_OVERTEMP_REG_ADDR, (OVER_TEMP_LIMIT*256));
        /*设置由高温降至某正常值 OS/ALERT引脚复位*/
        status = adsAPI_I2C_Reg_Write_Word(ADT75_DEV_ADDR, ADT75_HYST_REG_ADDR,     (HYST_TEMP_LIMIT*256));
        /*至于 OS/ALERT 极性由ADT75_CONFIG_REG_ADDR配置寄存器D2设置*/
    //=========================== Program Config Register to run ADT75 in Cont/one-shot mode =====================================//
    #ifdef LOWPOWER_EVENT_MODE
        status = adsAPI_I2C_Reg_Write_Byte(ADT75_DEV_ADDR, ADT75_CONFIG_REG_ADDR,  0x02);     //0x26 //Continuous mode + Interrupt enabled
    #else
        status = adsAPI_I2C_Reg_Write_Byte(ADT75_DEV_ADDR, ADT75_CONFIG_REG_ADDR,  0x22);     //0x26 //One-Shot mode
    #endif
        if(status == ADI_I2C_SUCCESS)
            return API_SUCCESS;
        else
            return API_FAIL;
  • 签到天数: 1617 天
    [LV.Master]伴坛终老
    发表于 2015-12-20 21:01:51 | 显示全部楼层
    数字温度传感器比较方便,就是成本高一些。
  • 签到天数: 222 天
    [LV.7]常住居民III
    发表于 2015-12-21 09:29:15 | 显示全部楼层
    多谢分享!
    GMT+8, 2024-4-30 00:38 , Processed in 0.135836 second(s), 20 queries , MemCache On.
