查看: 2359|回复: 0
[EVAL-WSN]操作系统篇——Contiki分析之timer
  • 签到天数: 971 天
    发表于 2016-1-23 09:33:26 | 显示全部楼层 |阅读模式
    contiki-2.5\core\sys\timer.c
    1 timer结构体
    struct timer {
      clock_time_t start;/* 开始时间 */
      clock_time_t interval;/* 时间间隔 */
        timer是一个独立结构,用于获取当前的时间,并计算时间间隔,本身并不能产生事件。一般用于内部进行的时间的获取,很少用于阻塞操作,使用后要手动激活任务
    2、timer 代码分析
    Functions
    void timer_set (struct timer *t, clock_time_t interval)
    Set a timer.
    void timer_reset (struct timer *t)
    Reset the timer with the same interval.
    void timer_restart (struct timer *t)
    Restart the timer from the current point in time.
    int timer_expired (struct timer *t)
    Check if a timer has expired.
    clock_time_t timer_remaining (struct timer *t)
    The time until the timer expires.
    1. void
    2. timer_set(struct timer *t, clock_time_t interval)
    3. {/*用当前时间初始化start,并设置间隔interval*/
    4.   t->interval = interval;
    5.   t->start = clock_time();
    6. }
    7. void
    8. timer_reset(struct timer *t)
    9. {
    10.   /*为什么不t->start = clock_time()?为了程序可预测性?
    11.     造成:clock_time() 不断增加,更不是固定的周期
    12.    */
    13.   t->start += t->interval;
    14. }
    15. void
    16. timer_restart(struct timer *t)
    17. {
    18.   t->start = clock_time();
    19. }
    20. int
    21. timer_expired(struct timer *t)
    22. {
    23.   /* Note: Can not return diff >= t->interval so we add 1 to diff and return
    24.      t->interval < diff - required to avoid an internal error in mspgcc. */
    25.   clock_time_t diff = (clock_time() - t->start) + 1;
    26.   return t->interval < diff;
    27. }
    28. clock_time_t
    29. timer_remaining(struct timer *t)
    30. {
    31.   return t->start + t->interval - clock_time();
    32. }
    GMT+8, 2024-5-3 14:52 , Processed in 0.105635 second(s), 15 queries , MemCache On.
