查看: 2360|回复: 9
[原创] TQ2440裸奔程序:串口UART的PC机按键测试程序
  • 签到天数: 112 天
    [LV.6]常住居民II
    发表于 2016-3-9 10:48:08 | 显示全部楼层 |阅读模式
      TQ2440 是由广州天嵌计算机科技有限公司精心打造的一款开发板。以稳定的性能,过硬的质量,丰富的扩展接口,优质的售后服务和技术支持,赢得众多企业的青睐和支持。
      // NAME: main.c
      // DESC: TQ2440串口UART测试程序
      /* 头文件包含 */
      #include "def.h"
      #include "option.h"
      #include "2440addr.h"
      #include
      #include
      #include
      #include
      #include
      static volatile int uart_port = 0;
      void uart_init(int pclk,int buad,int ch)
      //UART初始化:端口使能、功能设定、波特率、设置数据格式
      rGPHCON = (rGPHCON & ~(0xfff<<4)) | (0xaaa<<4);//端口RX[0:2]、TX[0:2]功能
      rGPHUP = rGPHUP | (0x7<<1); //端口GPH[1:3]禁止上拉
      rUFCON0 = 0x0; //禁止FIFO
      rUFCON1 = 0x0; //禁止FIFO
      rUFCON2 = 0x0; //禁止FIFO
      rUMCON0 = 0x0; //禁止AFC
      rUMCON1 = 0x0; //禁止AFC
      //Normal:No parity:One stop:8-bits 中断响应 UART clock: PCLK
      rULCON0 = (rULCON0 & ~0xff) | ((0x0<<6)|(0x0<<3)|(0x0<<2)|(0x3));
      rUCON0 = (rUCON0 & ~0x3ff) | ((0x1<<9)|(0x1<<6)|(0x1<<2)|(0x1));
      rUBRDIV0 = ((int)(pclk/16./buad+0.5)-1);
      rULCON1 = (rULCON1 & ~0xff) | ((0x0<<6)|(0x0<<3)|(0x0<<2)|(0x3));
      rUCON1 = (rUCON1 & ~0x3ff) | ((0x1<<9)|(0x1<<6)|(0x1<<2)|(0x1));
      rUBRDIV1 = ((int)(pclk/16./buad+0.5)-1);
      rULCON2 = (rULCON2 & ~0xff) | ((0x0<<6)|(0x0<<3)|(0x0<<2)|(0x3));
      rUCON2 = (rUCON2 & ~0x3ff) | ((0x1<<9)|(0x1<<6)|(0x1<<2)|(0x1));
      rUBRDIV2 = ((int)(pclk/16./buad+0.5)-1);
      uart_port = ch; //设置串口端口号
      // 串口发送函数
      void uart_send_byte(int data)
      if(0 == uart_port)
      if(data == 'n')
      while(!(rUTRSTAT0 & 0x2));
      rUTXH0 = 'n';
      rUTXH0 = data;
      else if(1 == uart_port)
      if(data == 'n')
      while(!(rUTRSTAT1 & 0x2));
      rUTXH1 = 'n';
      rUTXH1 = data;
      else if(2 == uart_port)
      if(data == 'n')
      while(!(rUTRSTAT2 & 0x2));
      rUTXH2 = 'n';
      rUTXH2 = data;
      void uart_send_string(char *string)
      while(*string)
      uart_send_byte(*string++);
      void uart_printf(char *fmt,...)
      va_list ap;
      char string[256];
      va_start(ap,fmt);
      vsprintf(string,fmt,ap);
      uart_send_string(string);
      va_end(ap);
      // 串口接收函数
      void uart_tx_empty(void)
      if(0 == uart_port)
      while(!(rUTRSTAT0 & 0x4));//等待Tx为空
      if(1 == uart_port)
      while(!(rUTRSTAT1 & 0x4));//等待Tx为空
      if(2 == uart_port)
      while(!(rUTRSTAT2 & 0x4));//等待Tx为空
      char uart_get_ch(void)
      if(0 == uart_port)
      while(!(rUTRSTAT0 & 0x1));//等待Rx被读
      return rURXH0; //读缓存寄存器
      while(!(rUTRSTAT1 & 0x1));//等待Rx被读
      return rURXH1; //读缓存寄存器
      while(!(rUTRSTAT2 & 0x1));//等待Rx被读
      return rURXH2; //读缓存寄存器
      return 0;
      char uart_get_key(void)
      if(0 == uart_port)
      if(rUTRSTAT0 & 0x1) //Rx被读
      else
      return 0;
      if(1 == uart_port)
      if(rUTRSTAT1 & 0x1) //Rx被读
      else
      return 0;
      if(2 == uart_port)
      if(rUTRSTAT2 & 0x1) //Rx被读
      else
      return 0;
      return 0;
      void uart_get_string(char *string)
      char *string1 = string;
      char c = 0;
      while((c = uart_get_ch())!='r')
      if(c == 'b')
      if((int)string1 < (int)string)
      uart_printf("bb");
      string--;
      else
      *string++ = c;
      uart_send_byte(c);
      *string = '�';
      uart_send_byte('n');
      int uart_get_intnum(void)
      char str[30];
      char *string = str;
      int base = 10;
      int minus = 0;
      int result = 0;
      int last_index;
      int i;
      uart_get_string(string);
      if(string[0] == '-')
      minus = 1;
      string++;
      if(string[0] == '0' && (string[1] == 'x' || string[1] == 'X'))
      base = 16;
      string = string + 2;
      last_index = strlen(string)-1;
      if(last_index < 0)
      return -1;
      if(string[last_index] == 'h' || string[last_index] == 'H')
      base = 16;
      string[last_index] = 0;
      last_index--;
      if(base == 10)
      //atoi将字符串转换为整型值
      result = atoi(string);
      result = minus ? (-1*result) : result;
      else
      for(i=0;i<=last_index;i++)
      //判断字符是否为英文字母,当为英文字母a-z或A-Z时,返回非零值,否则返回零。
      if(isalpha(string[i]))
      //isupper 判断字符是否为大写英文字母,当c为大写英文字母,返回非零值,否则返回零。
      if(isupper(string[i]))
      result = (result<<4) + string[i]-'A'+10;
      else
      result = (result<<4) + string[i]-'a'+10;
      else
      result = (result<<4) + string[i]-'0'+10;
      return result;
      int uart_get_intnum_gj(void)
      char string[16];
      char *p_string = string;
      char c;
      int i = 0;
      int data = 0;
      while((c = uart_get_ch()) != 'r')
      if(c == 'b')
      p_string--;
      else
      *p_string++ = c;
      //uart_send_byte(c);
      *p_string = '�';
      i=0;
      while(string[i] != '�')
      data = data*10;
      if(string[i]<'0' || string[i]>'9')
      return -1;
      data = data +(string[i]-'0');
      i++;
      return data;
      void Main(void)
      uart_init(50000000,115200,0);
      while(1)
      if('-' == uart_get_ch())
      uart_printf("+n");
      if('+' == uart_get_key())
      uart_printf("-n");
      感谢晨旭晚霞的支持!
      供货情况:
      天嵌科技提供专业嵌入式板卡和行业解决方案。如有需要,可以联系天嵌科技的销售人员。
      销售电话:020-38219416 38373101
      技术支持:020-38219416转807 820
      网址:http://www.embedsky.com
    发表于 2016-3-11 15:49:00 | 显示全部楼层
    学习了,谢谢楼主。
  • 签到天数: 4 天
    发表于 2016-3-11 20:14:20 | 显示全部楼层
    谢谢楼主分享,刚好我和同学在学。
    发表于 2016-3-13 23:00:52 | 显示全部楼层
    很久之前用过天嵌的2440学习了,现在改用i.mx6q了,资料挺多的
    发表于 2016-3-14 14:13:51 | 显示全部楼层
    同学说最近天嵌淘宝有优惠活动,包邮,还送ov9650摄像头跟视频教程光盘,可是我前一个星期就买了2440这套板子,问淘宝客服可不可以送我摄像头,客服说只能是活动期间购买才送……好吧,错过了活动,还好没错过楼主的资料分享!!!
    发表于 2016-3-14 16:17:46 | 显示全部楼层
    好同志看见好帖一定要顶的~
    发表于 2016-3-14 16:18:51 | 显示全部楼层
    已收藏分享哦~楼主麻溜点,多分享点资料哦~
    发表于 2016-3-16 10:23:07 | 显示全部楼层
    分享,分享,谢谢楼主!
  • 签到天数: 2 天
    发表于 2016-3-16 11:23:50 | 显示全部楼层
    因为一直都在用心,我们的客户是从学生做到企业,一路上来的,只要用过,终身难忘,所以我们知道感恩,只为让您的开发更容易
  • 签到天数: 2 天
    发表于 2016-3-16 11:26:28 | 显示全部楼层
    lyt2851297573 发表于 2016-3-14 14:13
    同学说最近天嵌淘宝有优惠活动,包邮,还送ov9650摄像头跟视频教程光盘,可是我前一个星期就买了2440这套板 ...
    活动还在进行中哦亲,如有需要,可以去我们淘宝看看哦
    GMT+8, 2024-4-29 22:40 , Processed in 0.216942 second(s), 33 queries , MemCache On.
