查看: 2019|回复: 2
Some problems about the bluetooth.
发表于 2016-8-12 13:22:33 | 显示全部楼层 |阅读模式
GutenTag
     Hello , legend infineon   FAE.
My cell phone can connect to the bluetooth module , the bluetooth APP shows "Connected" and Bluetooth LED bright red light . But bluetooth APP can't control the plane of the motor , the plane did not respond . Bluetooth application displays "Connected" can control the aircraft ? Whether there is a necessary operation ? Can you give me some tips ? Looking forward to your reply, thank you !
 楼主| 发表于 2016-8-12 13:24:17 | 显示全部楼层
  • 签到天数: 2 天
    发表于 2016-8-18 22:06:34 | 显示全部楼层
    飞控代码默认优先响应从板子RC-Control接口输入的遥控数据,要想直接使用APP遥控,需要指定飞控只响应APP的遥控,具体参考我的帖子,飞控套件上手ABC,可能还在审核中
    GMT+8, 2024-5-7 06:41 , Processed in 0.241715 second(s), 20 queries , MemCache On.
