查看: 4640|回复: 7
[配件] chipkit UNO32开发板配套书籍——Getting Started with chipKIT™
发表于 2012-8-8 11:37:13 | 显示全部楼层 |阅读模式
  • 原文由
  • mikeliujia
  • 发表自:dev.eefocus.com
  • Perfect for getting started with the chipKIT™Uno32
  • Incorporates simple, easy-to-understand example projects
  • Covers digital and analog input/output, the fundamental building blocks for every microcontroller project
  • Written by Chuck Hellebuyck
In this book, Chuck Hellebuyck, author of many entry-level technical books, shows you how to get started with the chipKIT™UNO32 using very simple example projects. These projects demonstrate the use of digital inputs & outputs, analog inputs & outputs, and more. These are the fundamental building blocks that every electronic project uses at its core. Learning the example projects in this book will give you the tools you need to get your future projects, gadgets or products up and running quickly and easily.
蹩脚翻译:Chuck Hellebuyck是许多入门级技术书籍的作者,在这本书里,他将通过非常简单的项目例子告诉你如何使用chipKIT™UNO32。这些项目涉及数字输入和输出,模拟输入和输出,以及其它更多的应用。这些是每一个电子项目将chipKIT™UNO32作为核心使用的基本构建块。学习这本书中的示例项目会使你掌握该工具从而轻松快捷地开发您未来的项目,小工具或产品。
Table of contents:
  • Chapter 1: What is chipKIT?
  • Chapter 2: Flash an External LED
  • Chapter 3: Train Crossing
  • Chapter 4: LED Traffic Light
  • Chapter 5: Scroll LEDs
  • Chapter 6: Sensing a Switch
  • Chapter 7: Read a Potentiometer
  • Chapter 8: Sensing Light
  • Chapter 9: Creating Sound
  • Chapter 10; Dimming an LED with PWM
  • Chapter 11: Serial Communication
  • Conclusion
  • Appendix A –Parts List for Projects
  • Appendix B – UNO32 Pin Map
Sample_chipKITminibookvol1.pdf (1.78 MB, 下载次数: 229)
  • 签到天数: 16 天
    [LV.4]偶尔看看III
    发表于 2014-1-24 13:57:03 | 显示全部楼层
    下载来看看,学习学习。
  • 签到天数: 1930 天
    [LV.Master]伴坛终老
    发表于 2014-5-3 21:47:36 | 显示全部楼层
    资料不错谢谢收了。。
  • 签到天数: 980 天
    发表于 2014-7-11 15:23:53 | 显示全部楼层
    怎么只有第一张啊?
  • 签到天数: 980 天
    发表于 2015-7-12 15:05:57 | 显示全部楼层
    有完整的中文版的吗?
  • 签到天数: 980 天
    发表于 2016-8-22 20:09:19 | 显示全部楼层
    我有中文版,有谁要的?
  • 签到天数: 827 天
    发表于 2017-12-22 22:21:03 | 显示全部楼层
    mcp2013 发表于 2016-8-22 20:09
    我有中文版,有谁要的?
    你好,可以发我邮箱吗?3455482668@qq.com,谢谢
    GMT+8, 2024-4-29 20:47 , Processed in 0.166194 second(s), 29 queries , MemCache On.
