查看: 3087|回复: 9
爱特梅尔公司之 SAMA5D33-EK
  • 签到天数: 361 天
    发表于 2013-3-11 09:23:28 | 显示全部楼层 |阅读模式
    The SAMA5D33-EK is a full-featured evaluation platform for the Atmel SAMA5D33
    embedded microprocessor. The kit consists of a main board, a computer module equipped with a SAMA5D33 processor, and a display module. It is supported by the SAMA5D3 Softpack, a free set of bare metal C examples, and is delivered with on-board demos for Linux and Qt-based GUI. The SAMA5D33-EK allows users to extensively evaluate, prototype and create applications that require graphics, audio, mass storage, networking, connectivity and more.
    Source files and binaries for the on-board demo are available on Linux4SAM, the entry point to open source solutions for Atmel ARM® core-based embedded microprocessors.
    关键特征:
    Atmel SAMA5D33 embedded MPU running at 536MHz in a BGA324 package
    4Gb DDR2, 2Gb NAND Flash, 128Mb NOR , 32Mb SPI Serial DataFlash, 512Kb EEPROM
    JLink and CDC on-board, optional JTAG test access port
    MII/RMII Ethernet 10/100 w/PHY
    RGMII Ethernet 1Gb w/PHY
    Four-wire RS232
    Two USB 2.0 Hosts, one USB 2.0 Host/Device
    Conexant CX20548 SmartDAA for soft modem implementation
    MicroSD card slot
    MMC/MMC+/SD/SDIO/CE-ATA
    Headphone output, line in and microphone
    One 5.0” WVGA resistive TFT LCD module with four QTouch keys
    One ISI interface for connection to a CMOS sensor
    One HDMI interface
    One 10-pin connector for Atmel RZ600 ZigBee® module
    Two CAN connectors
  • 签到天数: 361 天
    发表于 2013-3-11 09:32:43 | 显示全部楼层
    wyzamazon 发表于 2013-3-11 09:29
    啥时候做这个板子的活动就好了
    相信呼声越高可能性越大的哈
  • 签到天数: 980 天
    发表于 2013-3-11 09:52:24 | 显示全部楼层
    帖子发重复了
  • 签到天数: 361 天
    发表于 2013-3-11 09:56:16 | 显示全部楼层
    mcp2013 发表于 2013-3-11 09:52
    帖子发重复了
    SAMA5D33-EK    SAMA5D35-EK  一个系列,不是重复哟,亲
  • 签到天数: 980 天
    发表于 2013-3-11 10:17:25 | 显示全部楼层
    呵呵  不好意思    没看仔细
  • 签到天数: 361 天
    发表于 2013-3-11 10:23:39 | 显示全部楼层
    mcp2013 发表于 2013-3-11 10:17
    呵呵  不好意思    没看仔细
    没关系啦......
  • 签到天数: 692 天
    发表于 2013-3-11 18:17:58 | 显示全部楼层
    这个板子够强大,支持一个!
  • 签到天数: 257 天
    发表于 2013-7-3 16:41:57 | 显示全部楼层
    好强大的板子,这个做一般的影音播放,网络应用,智能设备比较好,跨行业的应用东西。不错不错
  • 签到天数: 368 天
    发表于 2013-7-3 17:44:57 | 显示全部楼层
    ATmel的高端芯片用的似乎不多啊。。
  • 签到天数: 125 天
    [LV.7]常住居民III
    发表于 2013-7-4 10:23:45 | 显示全部楼层
    这个公司我还停留在51的印象上
    GMT+8, 2024-5-9 04:57 , Processed in 0.225861 second(s), 33 queries , MemCache On.
