查看: 4101|回复: 9
[晒板] 晒板 + UDOO NEO,NXP imx6 晒板 + 开机
  • 签到天数: 592 天
    发表于 2017-11-25 18:53:43 | 显示全部楼层 |阅读模式
    题外话,开源Linux板子软件开源,硬件开源,(完全开源啊,不是部分开源),系统支持维护好又及时的 linux 板子,真是不多,也不太好找,这个算一个,还有大名鼎鼎的 beaglebone,都很不错。
    这个帖子说的,udoo neo 板子,顶配,该有的都有了,arm a9 单核,性能有点弱,研究 linux 妥妥的,完全够用了。
    板子小,使用起来很方便一根 usb 线搞定,供电 + usb 网口 ssh 登录。嗯,一块板子,加一根手机数据线,就可以愉快的玩起来了。
    板子是在mouer买的,链接:www.mouser.cn/ProductDetail/UDOO/SA69-0200-1100-C0/?qs=sGAEpiMZZMtzPgOfznR9QV8t4YZE6KzCRi%252buctlf%2fxU%3d
    单号:13123294
    udoo neo 详细规格:(顶配啊,也就是Full 版本,所有标识 or 呀,only 呀,这些特性,这个板子都有)
    Processor
    NXP® i.MX 6SoloX applications processor with an embedded ARM Cortex-A9 core and a Cortex-M4 Core
    Memory
    512MB (Basic) or 1GB (only Extended and Full)
    Graphics
    Integrated 2d/3d graphics controller
    Video Out
    Micro HDMI interface
    LVDS interface + touch (I2C signals)
    Video In
    Analog camera connection supporting NTSC and PAL
    8-bit parallel camera interface*
    Mass Storage
    MicroSD card slot onboard
    8-bit SDIO interface*
    Audio
    HDMI audio transmitter
    S/PIDF & I2S*
    USB
    1x USB 2.0 Type A ports
    1x USB OTG (micro-AB connector)
    Networking
    Fast ethernet RJ45 – 10/100Mbps (only Basic and Full)
    Wi-Fi 802.11 b/g/n,Direct Mode SmartConfig and Bluetooth 4.0 Low Energy
    Serial Ports
    3x UART ports*
    2x CAN Bus interfaces*
    Other Interfaces
    8x PWM signals*
    3x I2C interface*
    1x SPI interface*
    6x multiplexable signals*
    Power Supply
    5 V DC Micro USB
    6-15 V DC Power Jack
    RTC Battery Connector
    LEDs
    Green Power Status LED
    User Configurable LEDs (Red and Orange)
    Integrated Sensors
    3-Axis Accelerometer (only Extended and Full)
    3-Axis Magnetometer (only Extended and Full)
    3-Axis Digital Gyroscope (only Extended and Full)
    1x Sensor Snap-In I2C connector (only Extended and Full)
    Dimensions
    89mm x59mm (3.50″ x 2.32″)
    Arduino Pinout
    Arduino-Compatible through the standard Arduino Pins layout and compatible with Arduino shields.
    Digital I/O Pins
    32 extended GPIOs (A9 dedicated)
    22 arduino GPIOs (M4 dedicated)
    Analog Input Pins
    6 available Pins
    Operating System
    Android Marshmallow 6.0.1 & Linux UDOObuntu2 (14.04 LTS)
    开箱晒图
    普通纸盒包装,超大的 udoo neo,和官网
    背面,没说的,外国货,没有汉字。拿在手里沉甸甸的,有份量。
    侧面:wifi,蓝牙,4.0,板子特性
    侧面:板载 sensor 和支持的操作系统
    封装标签带着 udoo 的小手图案
    打开是个二维码,没扫过,不知道是啥,看样子应该是个介绍,或者说明吧,what can udoo?介绍这个板子能干啥
    仔细看包装盒子内表面
    包装盒里里外外每一寸空间都标识着板子的信息,利用率很高。
    这是主角,udoo neo 板子,装在静电袋中,上下垫两块海绵装在包装盒子里。
    板子上重要芯片,和所有接口,这么对比着看,是不是很方便。每一个 gpio 都标识出来了
    这个是板子背面
    主芯片 nxp imx6solox
    ti wl18 wifi bt 芯片。和 beaglebone black wireless 用的芯片同一个系列
    UDOO NEO,NXP imx6 开机
    硬件准备:
    1条usb 线,一个 tf 卡,udoo neo 板子。
    软件准备:
    下载官方制作好的镜像文件:https://www.udoo.org/downloads/,
    提示:下载时候很慢,多试几次,耐心等下载完。
    本帖用的:UDOObuntu 2.1.4 Minimal (14.04 LTS),下载后,解压出img 文件
    Win 电脑需要:下载安装Win32DiskImager软件,putty 软件
    制作启动卡,开机:
    使用 Win32DiskImager 把 img 文件写入 tf 卡中。
    完成后,tf 卡插入 udoo neo板子,usb 线连上电脑,板子自启动开机。
    电脑设备管理器多两个设备,一个是大容量存储,一个是感叹号设备/未知设备或者是个RNDIS 设备,usb ssh 登录需要用RNDIS,需要安装设备驱动。
    安装驱动:更新驱动=>浏览我的计算机以查找驱动程序软件=>从我的计算机上的可用驱动程序列表中选取=>厂商:microsoft,型号:远程NDIS 兼容设备(或者usb RNDIS 适配器/ usb RNDIS6 适配器,测试过的,这三个驱动都可以用)
    安装后电脑设别管理器=>网络适配器下就出现远程NDIS 兼容设备。开发板重启一下。
    Putty 登录:
    ssh 登录192.168.7.2,
    用户名/密码:udooer/udooer,root/ubuntu
    到此用官方制作好的镜像可以愉快地玩耍了:
    空载稍微能感觉到芯片的温度。
    稍后更新编译 uboot kernel rootfs 制作 tf 启动卡,自己编译好处是可以深入内核研究系统和底层。
    <未完待续......>
    可写的东西还不少,准备弄个连载帖,后面的内容在这里发:http://jingyan.eeboard.com/user/3431277
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2017-11-26 15:18:47 | 显示全部楼层
    我的刚入手看起来很高大上,用起来还是略坑的,RTC问题一年多了没解决,然后论坛再问,管理说我们没搞定也以为你们忘了这个事。。。
  • 签到天数: 592 天
     楼主| 发表于 2017-11-26 15:50:58 | 显示全部楼层
    sjqlwy 发表于 2017-11-26 15:18
    我的刚入手看起来很高大上,用起来还是略坑的,RTC问题一年多了没解决,然后论坛再问,管理说我们没搞定也 ...
    这板子 2015 年开卖,相对还算新,不知道会不会像 beaglebone 那么长期的支持维护
    udoo 在 nxp 社区维护的板子里还算可以。
    你啥时候入手的板子,我的是刚刚到手,准备先照着官网搞一遍,
    发表于 2017-11-27 08:51:50 | 显示全部楼层
    厉害了,等待的你更新的开机帖
  • 签到天数: 28 天
    [LV.4]偶尔看看III
    发表于 2017-11-29 13:08:22 | 显示全部楼层
    udoo 在 nxp 社区维护 ...
    我是neo ext,入手快两年了吧,刚入手很喜欢,用料做工很不错,不过意呆利厂家去搞udoo x86了,这个就不是重点。
    采用i.mx6solox,可玩性有,但是社区小,更新慢,还是很头疼的,准备出掉了
  • 签到天数: 592 天
     楼主| 发表于 2017-11-30 14:26:13 | 显示全部楼层
    sjqlwy 发表于 2017-11-29 13:08
    我是neo ext,入手快两年了吧,刚入手很喜欢,用料做工很不错,不过意呆利厂家去搞udoo x86了,这个就不 ...
    那你买的早,除了网线接口,其他全都一样。
    我现在学会了,太老的板子不买,太新的也不买,小众板子不买,不开源的不买,软件维护支持不给力也不买,算下来还真没有多少挑的了
  • 签到天数: 1088 天
    连续签到: 2 天
    发表于 2017-12-4 08:25:17 | 显示全部楼层
    这个板子能学好很不错。
  • 签到天数: 592 天
     楼主| 发表于 2017-12-28 16:31:57 | 显示全部楼层
    yanhaijian 发表于 2017-12-4 08:25
    这个板子能学好很不错。
    准备一点点都写出来:
  • 签到天数: 592 天
     楼主| 发表于 2017-12-28 16:32:56 | 显示全部楼层
    enly 发表于 2017-11-27 08:51
    厉害了,等待的你更新的开机帖
    开机,上手已经用上了:
    发表于 2018-1-4 11:41:13 | 显示全部楼层
    关注这个板子很久了。一直在纠结要不要入手。
    手里有树莓派3B,nanopi neo。但是树莓派不是完全开源。而这个板子完全开源,至少可以玩一下芯片底层的东西。期待楼主的更新。
    点评
    后面的东西更新到这个地方了,更新了 7 -8 篇了 http://jingyan.eeboard.com/user/3431277  发表于 2018-1-4 15:14
    GMT+8, 2024-5-6 18:38 , Processed in 0.209663 second(s), 35 queries , MemCache On.
