回答
收藏
[原创] 【MYD-Y6ULX】上电开机,预装系统试用
嵌入式系统 嵌入式系统 7436 人阅读 | 0 人回复 | 2018-02-26
上电开机:
没有lcd屏,只能用debug接口,通过usb ttl串口模块连接到电脑上:
电脑打开putty,我的是com3端口,115200,8n1,打开:
开发板通电,debug旁边的5v红色指示灯常亮,蓝色led心跳灯闪烁,串口有输出信息:
  1. U-Boot 2016.03-mys-6ulx+g9008006 (Jan 16 2018 - 16:55:05 +0800)
  2. CPU:   Freescale i.MX6UL rev1.2 528 MHz (running at 396 MHz)
  3. CPU:   Industrial temperature grade (-40C to 105C) at 24C
  4. Reset cause: POR
  5. Board: MYD-Y6UL 14x14
  6. I2C:   ready
  7. DRAM:  256 MiB
  8. NAND:  256 MiB
  9. MMC:   MMC/SD: Reset never completed.
  10. voltage not supported by controller
  11. Warning: failed to initialize mmc dev 1
  12. FSL_SDHC: 0
  13. *** Warning - bad CRC, using default environment
  14. Display: TFT43AB (480x272)
  15. Video: 480x272x24
  16. In:    serial
  17. Out:   serial
  18. Err:   serial
  19. Net:   Board Net Initialization Failed
  20. No ethernet found.
  21. Normal Boot
  22. Hit any key to stop autoboot:  0
  23. NAND read: device 0 offset 0x500000, size 0xa00000
  24. 10485760 bytes read: OK
  25. NAND read: device 0 offset 0xf00000, size 0x100000
  26. 1048576 bytes read: OK
  27. Kernel image @ 0x80800000 [ 0x000000 - 0x602380 ]
  28. ## Flattened Device Tree blob at 83000000
  29.    Booting using the fdt blob at 0x83000000
  30.    Using Device Tree in place at 83000000, end 8300c1d3
  31. Modify /soc/aips-bus@02000000/bee@02044000:status disabled
  32. ft_system_setup for mx6
  33. Starting kernel ...
  34. Booting Linux on physical CPU 0x0
  35. Linux version 4.1.15-1.2.0+g6ae884d (blackrose@brix4770-debian) (gcc version 5.3.0 (GCC) ) #1 SMP PREEMPT Wed Jan 24 11:04:25 CST 2018
  36. CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
  37. CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
  38. Machine model: Freescale i.MX6 UltraLite 14x14 EVK Board
  39. Reserved memory: failed to allocate memory for node 'linux,cma'
  40. Memory policy: Data cache writealloc
  41. PERCPU: Embedded 12 pages/cpu @8fdd3000 s16908 r8192 d24052 u49152
  42. Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
  43. Kernel command line: console=ttymxc0,115200 ubi.mtd=3 root=ubi0:rootfs rootfstype=ubifs mtdparts=gpmi-nand:5m(boot),10m(kernel),1m(dtb),-(rootfs)
  44. PID hash table entries: 1024 (order: 0, 4096 bytes)
  45. Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
  46. Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
  47. Memory: 247644K/262144K available (7847K kernel code, 429K rwdata, 2860K rodata, 424K init, 441K bss, 14500K reserved, 0K cma-reserved, 0K highmem)
  48. Virtual kernel memory layout:
  49.     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
  50.     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
  51.     vmalloc : 0x90800000 - 0xff000000   (1768 MB)
  52.     lowmem  : 0x80000000 - 0x90000000   ( 256 MB)
  53.     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
  54.     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
  55.       .text : 0x80008000 - 0x80a7d0f0   (10709 kB)
  56.       .init : 0x80a7e000 - 0x80ae8000   ( 424 kB)
  57.       .data : 0x80ae8000 - 0x80b53720   ( 430 kB)
  58.        .bss : 0x80b56000 - 0x80bc45b8   ( 442 kB)
  59. SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
  60. Preemptible hierarchical RCU implementation.
  61.         Additional per-CPU info printed with stalls.
  62.         RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
  63. RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
  64. NR_IRQS:16 nr_irqs:16 16
  65. mxc_clocksource_init 24000000
  66. Switching to timer-based delay loop, resolution 41ns
  67. sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
  68. clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
  69. Console: colour dummy device 80x30
  70. Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
  71. pid_max: default: 32768 minimum: 301
  72. Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
  73. Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
  74. CPU: Testing write buffer coherency: ok
  75. /cpus/cpu@0 missing clock-frequency property
  76. CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
  77. Setting up static identity map for 0x80008280 - 0x800082d8
  78. Brought up 1 CPUs
  79. SMP: Total of 1 processors activated (48.00 BogoMIPS).
  80. CPU: All CPU(s) started in SVC mode.
  81. devtmpfs: initialized
  82. device-tree: Duplicate name in lcdif@021c8000, renamed to "display#1"
  83. VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
  84. clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
  85. pinctrl core: initialized pinctrl subsystem
  86. NET: Registered protocol family 16
  87. DMA: preallocated 256 KiB pool for atomic coherent allocations
  88. cpuidle: using governor ladder
  89. cpuidle: using governor menu
  90. hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
  91. hw-breakpoint: maximum watchpoint size is 8 bytes.
  92. imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
  93. mxs-dma 1804000.dma-apbh: initialized
  94. SCSI subsystem initialized
  95. usbcore: registered new interface driver usbfs
  96. usbcore: registered new interface driver hub
  97. usbcore: registered new device driver usb
  98. i2c i2c-1: IMX I2C adapter registered
  99. i2c i2c-1: can't use DMA
  100. media: Linux media interface: v0.10
  101. Linux video capture interface: v2.00
  102. pps_core: LinuxPPS API ver. 1 registered
  103. pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
  104. PTP clock support registered
  105. MIPI CSI2 driver module loaded
  106. Advanced Linux Sound Architecture Driver Initialized.
  107. Switched to clocksource mxc_timer1
  108. NET: Registered protocol family 2
  109. TCP established hash table entries: 2048 (order: 1, 8192 bytes)
  110. TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
  111. TCP: Hash tables configured (established 2048 bind 2048)
  112. UDP hash table entries: 256 (order: 1, 8192 bytes)
  113. UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
  114. NET: Registered protocol family 1
  115. RPC: Registered named UNIX socket transport module.
  116. RPC: Registered udp transport module.
  117. RPC: Registered tcp transport module.
  118. RPC: Registered tcp NFSv4.1 backchannel transport module.
  119. imx rpmsg driver is registered.
  120. Bus freq driver module loaded
  121. futex hash table entries: 256 (order: 2, 16384 bytes)
  122. VFS: Disk quotas dquot_6.6.0
  123. VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
  124. NFS: Registering the id_resolver key type
  125. Key type id_resolver registered
  126. Key type id_legacy registered
  127. jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
  128. fuse init (API version 7.23)
  129. io scheduler noop registered
  130. io scheduler deadline registered
  131. io scheduler cfq registered (default)
  132. imx-weim 21b8000.weim: Driver registered.
  133. backlight supply power not found, using dummy regulator
  134. MIPI DSI driver module loaded
  135. MIPI DSI driver module loaded
  136. 21c8000.lcdif supply lcd not found, using dummy regulator
  137. mxsfb 21c8000.lcdif: failed to find mxc display driver
  138. Console: switching to colour frame buffer device 60x34
  139. mxsfb 21c8000.lcdif: initialized
  140. imx-sdma 20ec000.sdma: no event needs to be remapped
  141. imx-sdma 20ec000.sdma: loaded firmware 3.3
  142. imx-sdma 20ec000.sdma: initialized
  143. 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 20, base_baud = 5000000) is a IMX
  144. console [ttymxc0] enabled
  145. 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 232, base_baud = 5000000) is a IMX
  146. 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 233, base_baud = 5000000) is a IMX
  147. imx sema4 driver is registered.
  148. [drm] Initialized drm 1.1.0 20060810
  149. [drm] Initialized vivante 1.0.0 20120216 on minor 0
  150. brd: module loaded
  151. loop: module loaded
  152. nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
  153. nand: Micron MT29F2G08ABAEAWP
  154. nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
  155. gpmi-nand 1806000.gpmi-nand: enable the asynchronous EDO mode 5
  156. Bad block table found at page 131008, version 0x01
  157. Bad block table found at page 130944, version 0x01
  158. 4 cmdlinepart partitions found on MTD device gpmi-nand
  159. Creating 4 MTD partitions on "gpmi-nand":
  160. 0x000000000000-0x000000500000 : "boot"
  161. 0x000000500000-0x000000f00000 : "kernel"
  162. 0x000000f00000-0x000001000000 : "dtb"
  163. 0x000001000000-0x000010000000 : "rootfs"
  164. gpmi-nand 1806000.gpmi-nand: driver registered.
  165. CAN device driver interface
  166. flexcan 2094000.can: device registered (reg_base=92a48000, irq=29)
  167. 20b4000.ethernet supply phy not found, using dummy regulator
  168. pps pps0: new PPS source ptp0
  169. fec 20b4000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
  170. fec 20b4000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 0a:fa:af:b3:1d:66
  171. libphy: fec_enet_mii_bus: probed
  172. fec 20b4000.ethernet eth0: registered PHC device 0
  173. 2188000.ethernet supply phy not found, using dummy regulator
  174. pps pps1: new PPS source ptp1
  175. fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
  176. fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: 8a:cf:81:73:12:d3
  177. fec 2188000.ethernet eth1: registered PHC device 1
  178. PPP generic driver version 2.4.2
  179. PPP BSD Compression module registered
  180. PPP Deflate Compression module registered
  181. PPP MPPE Compression module registered
  182. NET: Registered protocol family 24
  183. SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
  184. CSLIP: code copyright 1989 Regents of the University of California.
  185. SLIP linefill/keepalive option.
  186. ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
  187. ehci-mxc: Freescale On-Chip EHCI Host driver
  188. usbcore: registered new interface driver usb-storage
  189. usbcore: registered new interface driver usbserial
  190. usbcore: registered new interface driver usbserial_generic
  191. usbserial: USB Serial support registered for generic
  192. usbcore: registered new interface driver option
  193. usbserial: USB Serial support registered for GSM modem (1-port)
  194. usbcore: registered new interface driver usb_ehset_test
  195. 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
  196. 2184000.usb supply vbus not found, using dummy regulator
  197. 2184200.usb supply vbus not found, using dummy regulator
  198. ci_hdrc ci_hdrc.1: EHCI Host Controller
  199. ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
  200. ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
  201. hub 1-0:1.0: USB hub found
  202. hub 1-0:1.0: 1 port detected
  203. mousedev: PS/2 mouse device common for all mice
  204. input: 20cc000.snvs:snvs-powerkey as /devices/platform/soc/2000000.aips-bus/20cc000.snvs/20cc000.snvs:snvs-powerkey/input/input0
  205. tp reset gpio=130
  206. msg ft5x0x_i2c_rxdata i2c read error: -5
  207. ft5x0x read ID error!
  208. ft5x06_ts: probe of 1-0038 failed with error 161
  209. ft5x0x_ts_init successful
  210. input: iMX6UL TouchScreen Controller as /devices/platform/soc/2000000.aips-bus/2040000.tsc/input/input1
  211. snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
  212. i2c /dev entries driver
  213. IR NEC protocol handler initialized
  214. IR RC5(x/sz) protocol handler initialized
  215. IR RC6 protocol handler initialized
  216. IR JVC protocol handler initialized
  217. IR Sony protocol handler initialized
  218. IR SANYO protocol handler initialized
  219. IR Sharp protocol handler initialized
  220. IR MCE Keyboard/mouse protocol handler initialized
  221. IR XMP protocol handler initialized
  222. pxp-v4l2 pxp_v4l2: initialized
  223. usbcore: registered new interface driver uvcvideo
  224. USB Video Class driver (1.1.1)
  225. sdhci: Secure Digital Host Controller Interface driver
  226. sdhci: Copyright(c) Pierre Ossman
  227. sdhci-pltfm: SDHCI platform and OF driver helper
  228. /soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
  229. sdhci-esdhc-imx 2190000.usdhc: could not get ultra high speed state, work on normal mode
  230. sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
  231. sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
  232. mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
  233. /soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified
  234. sdhci-esdhc-imx 2194000.usdhc: could not get ultra high speed state, work on normal mode
  235. sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found
  236. sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
  237. mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
  238. caam 2140000.caam: Entropy delay = 3200
  239. caam 2140000.caam: Instantiated RNG4 SH0
  240. usb 1-1: new high-speed USB device number 2 using ci_hdrc
  241. mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
  242. mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
  243. mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
  244. mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
  245. mmc1: queuing unknown CIS tuple 0x80 (10 bytes)
  246. caam 2140000.caam: Instantiated RNG4 SH1
  247. caam 2140000.caam: device ID = 0x0a16030000000000 (Era -524)
  248. caam 2140000.caam: job rings = 3, qi = 0
  249. mmc1: new high speed SDIO card at address 0001
  250. hub 1-1:1.0: USB hub found
  251. hub 1-1:1.0: 4 ports detected
  252. caam algorithms registered in /proc/crypto
  253. caam_jr 2141000.jr0: registering rng-caam
  254. platform caam_sm: blkkey_ex: 8 keystore units available
  255. platform caam_sm: 64-bit clear key:
  256. platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
  257. platform caam_sm: 64-bit black key:
  258. platform caam_sm: [0000] 3a 83 0c 9e bf e9 5f c9
  259. platform caam_sm: [0008] 5b 52 2c be 2f ac 09 5c
  260. platform caam_sm: 128-bit clear key:
  261. platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
  262. platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
  263. platform caam_sm: 128-bit black key:
  264. platform caam_sm: [0000] 0a f7 c1 1a 4f 42 36 39
  265. platform caam_sm: [0008] 64 9f 9d 4f 4e ef c6 31
  266. platform caam_sm: 192-bit clear key:
  267. platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
  268. platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
  269. platform caam_sm: [0016] 10 11 12 13 14 15 16 17
  270. platform caam_sm: 192-bit black key:
  271. platform caam_sm: [0000] f2 91 ef 9d 75 4d 0f 72
  272. platform caam_sm: [0008] 63 0e f8 e3 e4 f8 1e 9b
  273. platform caam_sm: [0016] 84 a3 08 bd 74 d5 97 55
  274. platform caam_sm: [0024] 88 96 e6 b2 ed 59 01 52
  275. platform caam_sm: 256-bit clear key:
  276. platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
  277. platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
  278. platform caam_sm: [0016] 10 11 12 13 14 15 16 17
  279. platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
  280. platform caam_sm: 256-bit black key:
  281. platform caam_sm: [0000] 2b 14 d6 d7 22 c6 f7 cb
  282. platform caam_sm: [0008] f6 8d a1 55 b7 2b c3 5a
  283. platform caam_sm: [0016] 03 e9 2b 50 ec 82 ad 42
  284. platform caam_sm: [0024] 48 09 8c eb 7e 8a 3c 3b
  285. platform caam_sm: 64-bit unwritten blob:
  286. platform caam_sm: [0000] 00 00 00 00 00 00 00 00
  287. platform caam_sm: [0008] 00 00 00 00 00 00 00 00
  288. platform caam_sm: [0016] 00 00 00 00 00 00 00 00
  289. platform caam_sm: [0024] 00 00 00 00 00 00 00 00
  290. platform caam_sm: [0032] 00 00 00 00 00 00 00 00
  291. platform caam_sm: [0040] 00 00 00 00 00 00 00 00
  292. platform caam_sm: [0048] 00 00 00 00 00 00 00 00
  293. platform caam_sm: [0056] 00 00 00 00 00 00 00 00
  294. platform caam_sm: [0064] 00 00 00 00 00 00 00 00
  295. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
  296. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
  297. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
  298. platform caam_sm: 128-bit unwritten blob:
  299. platform caam_sm: [0000] 00 00 00 00 00 00 00 00
  300. platform caam_sm: [0008] 00 00 00 00 00 00 00 00
  301. platform caam_sm: [0016] 00 00 00 00 00 00 00 00
  302. platform caam_sm: [0024] 00 00 00 00 00 00 00 00
  303. platform caam_sm: [0032] 00 00 00 00 00 00 00 00
  304. platform caam_sm: [0040] 00 00 00 00 00 00 00 00
  305. platform caam_sm: [0048] 00 00 00 00 00 00 00 00
  306. platform caam_sm: [0056] 00 00 00 00 00 00 00 00
  307. platform caam_sm: [0064] 00 00 00 00 00 00 00 00
  308. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
  309. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
  310. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
  311. platform caam_sm: 196-bit unwritten blob:
  312. platform caam_sm: [0000] 00 00 00 00 00 00 00 00
  313. platform caam_sm: [0008] 00 00 00 00 00 00 00 00
  314. platform caam_sm: [0016] 00 00 00 00 00 00 00 00
  315. platform caam_sm: [0024] 00 00 00 00 00 00 00 00
  316. platform caam_sm: [0032] 00 00 00 00 00 00 00 00
  317. platform caam_sm: [0040] 00 00 00 00 00 00 00 00
  318. platform caam_sm: [0048] 00 00 00 00 00 00 00 00
  319. platform caam_sm: [0056] 00 00 00 00 00 00 00 00
  320. platform caam_sm: [0064] 00 00 00 00 00 00 00 00
  321. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
  322. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
  323. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
  324. platform caam_sm: 256-bit unwritten blob:
  325. platform caam_sm: [0000] 00 00 00 00 00 00 00 00
  326. platform caam_sm: [0008] 00 00 00 00 00 00 00 00
  327. platform caam_sm: [0016] 00 00 00 00 00 00 00 00
  328. platform caam_sm: [0024] 00 00 00 00 00 00 00 00
  329. platform caam_sm: [0032] 00 00 00 00 00 00 00 00
  330. platform caam_sm: [0040] 00 00 00 00 00 00 00 00
  331. platform caam_sm: [0048] 00 00 00 00 00 00 00 00
  332. platform caam_sm: [0056] 00 00 00 00 00 00 00 00
  333. platform caam_sm: [0064] 00 00 00 00 00 00 00 00
  334. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
  335. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
  336. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
  337. platform caam_sm: 64-bit black key in blob:
  338. platform caam_sm: [0000] 22 22 5f 35 a5 12 9d 7d
  339. platform caam_sm: [0008] eb 2e 69 f9 e0 37 f6 40
  340. platform caam_sm: [0016] ea a9 3e be cc de 41 dd
  341. platform caam_sm: [0024] fc 62 31 ee 92 cd cb 46
  342. platform caam_sm: [0032] ee 02 ec f2 4b a4 1e ce
  343. platform caam_sm: [0040] f1 a9 70 81 f1 f5 cf 8e
  344. platform caam_sm: [0048] 7b 73 16 9a 76 cd aa 0f
  345. platform caam_sm: [0056] 00 00 00 00 00 00 00 00
  346. platform caam_sm: [0064] 00 00 00 00 00 00 00 00
  347. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
  348. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
  349. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
  350. platform caam_sm: 128-bit black key in blob:
  351. platform caam_sm: [0000] 16 15 90 13 bd b6 5c e3
  352. platform caam_sm: [0008] f2 2f ba 35 99 3a 1e 2e
  353. platform caam_sm: [0016] b9 a1 ea 41 3f cb 43 28
  354. platform caam_sm: [0024] 38 e8 9f 29 e6 85 80 0f
  355. platform caam_sm: [0032] d5 17 89 00 d5 e7 ef c0
  356. platform caam_sm: [0040] 19 ab 9e 3c 20 7a 4c 1e
  357. platform caam_sm: [0048] 32 84 0f 20 98 ab 38 58
  358. platform caam_sm: [0056] 90 8c 3f 14 3c fc e0 c1
  359. platform caam_sm: [0064] 00 00 00 00 00 00 00 00
  360. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
  361. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
  362. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
  363. platform caam_sm: 192-bit black key in blob:
  364. platform caam_sm: [0000] 08 25 9f 71 6c c6 b1 97
  365. platform caam_sm: [0008] 92 23 87 cb b9 cb 32 5d
  366. platform caam_sm: [0016] f7 e0 6a 9a 8c f7 27 b1
  367. platform caam_sm: [0024] 4c 66 89 af 6a e0 4e 2b
  368. platform caam_sm: [0032] 77 4e 79 55 57 5d ad 1c
  369. platform caam_sm: [0040] 1b 76 b4 aa c1 ef cd 2b
  370. platform caam_sm: [0048] 3f 92 6f c4 31 28 13 22
  371. platform caam_sm: [0056] fa 60 c1 0f a5 93 a3 c2
  372. platform caam_sm: [0064] c6 3c ba 94 60 bb da 92
  373. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
  374. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
  375. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
  376. platform caam_sm: 256-bit black key in blob:
  377. platform caam_sm: [0000] fa 32 bd 4c ef b8 89 0b
  378. platform caam_sm: [0008] 13 1d 36 15 cf 4b f0 85
  379. platform caam_sm: [0016] 77 44 23 8a 73 10 6b 1e
  380. platform caam_sm: [0024] 6d e3 21 8d 4f 9d 32 99
  381. platform caam_sm: [0032] 6f 2b f2 99 b5 f7 92 f6
  382. platform caam_sm: [0040] a0 e1 a5 90 7f 10 3a 56
  383. platform caam_sm: [0048] bd d1 7f d2 08 22 eb 1c
  384. platform caam_sm: [0056] aa 7e 34 d7 23 e3 35 78
  385. platform caam_sm: [0064] 4a c0 86 48 29 b7 0f e9
  386. platform caam_sm: [0072] 2b f1 47 89 7e b7 d3 3e
  387. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
  388. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
  389. platform caam_sm: restored 64-bit black key:
  390. platform caam_sm: [0000] 63 9e 7a fb 05 88 ce 33
  391. platform caam_sm: [0008] 7f 86 8f 81 90 2a bb 9e
  392. platform caam_sm: restored 128-bit black key:
  393. platform caam_sm: [0000] 0a f7 c1 1a 4f 42 36 39
  394. platform caam_sm: [0008] 64 9f 9d 4f 4e ef c6 31
  395. platform caam_sm: restored 192-bit black key:
  396. platform caam_sm: [0000] f2 91 ef 9d 75 4d 0f 72
  397. platform caam_sm: [0008] 63 0e f8 e3 e4 f8 1e 9b
  398. platform caam_sm: [0016] 2a ce 5c f4 d8 f4 5a 9e
  399. platform caam_sm: [0024] f7 3c a1 2d 62 c7 21 ab
  400. platform caam_sm: restored 256-bit black key:
  401. platform caam_sm: [0000] 2b 14 d6 d7 22 c6 f7 cb
  402. platform caam_sm: [0008] f6 8d a1 55 b7 2b c3 5a
  403. platform caam_sm: [0016] 03 e9 2b 50 ec 82 ad 42
  404. platform caam_sm: [0024] 48 09 8c eb 7e 8a 3c 3b
  405. snvs-secvio 20cc000.caam-snvs: can't get snvs clock
  406. snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
  407. usbcore: registered new interface driver usbhid
  408. usbhid: USB HID core driver
  409. usbcore: registered new interface driver snd-usb-audio
  410. 1-001a supply DCVDD not found, using dummy regulator
  411. 1-001a supply DBVDD not found, using dummy regulator
  412. 1-001a supply AVDD not found, using dummy regulator
  413. 1-001a supply CPVDD not found, using dummy regulator
  414. 1-001a supply MICVDD not found, using dummy regulator
  415. wm8904 1-001a: Failed to read ID register: -5
  416. wm8904: probe of 1-001a failed with error -5
  417. fsl-asrc 2034000.asrc: driver registered
  418. imx-wm8904 sound: failed to find codec platform device
  419. imx-wm8904: probe of sound failed with error -22
  420. NET: Registered protocol family 26
  421. NET: Registered protocol family 10
  422. sit: IPv6 over IPv4 tunneling driver
  423. NET: Registered protocol family 17
  424. can: controller area network core (rev 20120528 abi 9)
  425. NET: Registered protocol family 29
  426. can: raw protocol (rev 20120528)
  427. can: broadcast manager protocol (rev 20120528 t)
  428. can: netlink gateway (rev 20130117) max_hops=1
  429. 8021q: 802.1Q VLAN Support v1.8
  430. Key type dns_resolver registered
  431. ubi0: attaching mtd3
  432. random: nonblocking pool is initialized
  433. ubi0: scanning is finished
  434. ubi0: attached mtd3 (name "rootfs", size 240 MiB)
  435. ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
  436. ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
  437. ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
  438. ubi0: good PEBs: 1916, bad PEBs: 4, corrupted PEBs: 0
  439. ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
  440. ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 841800621
  441. ubi0: available PEBs: 0, total reserved PEBs: 1916, PEBs reserved for bad PEB handling: 36
  442. ubi0: background thread "ubi_bgt0d" started, PID 139
  443. input: gpio-keys as /devices/platform/gpio-keys/input/input2
  444. snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:02 UTC (2)
  445. VSD_3V3: disabling
  446. can-3v3: disabling
  447. ALSA device list:
  448.   No soundcards found.
  449. UBIFS (ubi0:0): recovery needed
  450. UBIFS (ubi0:0): recovery deferred
  451. UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs", R/O mode
  452. UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
  453. UBIFS (ubi0:0): FS size: 236683264 bytes (225 MiB, 1864 LEBs), journal size 11808768 bytes (11 MiB, 93 LEBs)
  454. UBIFS (ubi0:0): reserved for root: 4952683 bytes (4836 KiB)
  455. UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID ACA63601-7726-4139-B9C2-FF8D33EF605B, small LPT model
  456. VFS: Mounted root (ubifs filesystem) readonly on device 0:14.
  457. devtmpfs: mounted
  458. Freeing unused kernel memory: 424K (80a7e000 - 80ae8000)
  459. INIT: version 2.88 booting
  460. Starting udev
  461. udevd[175]: starting version 3.1.5
  462. UBIFS (ubi0:0): completing deferred recovery
  463. UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 209
  464. UBIFS (ubi0:0): deferred recovery completed
  465. ov2659 1-0030: Sensor soft reset failed
  466. bootlogd: cannot allocate pseudo tty: No such file or directory
  467. brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d
  468. brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
  469. ALSA: Restoring mixer settings...
  470. Wed Jan 24 03:05:50 UTC 2018
  471. /usr/sbin/alsactl: load_state:1735: No soundcards found...
  472. INIT: Entering runlevel: 5
  473. Configuring network interfaces... fec 20b4000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=20b4000.ethernet:01, irq=-1)
  474. IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
  475. udhcpc (v1.24.1) started
  476. Sending discover...
  477. Sending discover...
  478. Sending discover...
  479. No lease, forking to background
  480. done.
  481. Starting system message bus: dbus.
  482. Starting OpenBSD Secure Shell server: sshd
  483.   generating ssh RSA key...
  484.   generating ssh ECDSA key...
  485.   generating ssh DSA key...
  486.   generating ssh ED25519 key...
  487. done.
  488. Starting rpcbind daemon...done.
  489. Starting advanced power management daemon: No APM support in kernel
  490. (failed.)
  491. Starting syslogd/klogd: done
  492. * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
  493.    ...done.
  494. Starting Telephony daemon
  495. Starting Linux NFC daemon
  496. Running local boot scripts (/etc/rc.local).
  497. xres = 480, yres = 272
  498. Freescale i.MX Release Distro 4.1.15-2.0.1 myd-y6ul14x14 /dev/ttymxc0
  499. myd-y6ul14x14 login: root
  500. root@myd-y6ul14x14:~# ls /
  501. bin    dev    home   media  proc   sbin   tmp    var
  502. boot   etc    lib    mnt    run    sys    usr
官方的预装的是Freescale i.MX Release Distro4.1.15-2.0.1系统,busybox轻量级的,相对小简单,系统占用cpumemory也没多少:
Nand flash占用的比较多,预装的系统50多兆占用了25%,工控就是工控,没办法自己折腾:(15GB和479GB两个是我自己的盘,不是板子自带的)
这个是nand flash 的分区信息:
0是uboot分区,5兆大小
1是kernel分区,2是dtb,3是rootfs,单位都是KB
Cpu信息:
内存:
Modules:
手动加载了个modules:看样子应该是示例代码会用到这个modules
系统是这个版本;工具链比常用的版本高,奇怪的是:工具链也不是系统光盘上那个版本,这就有点意思了:(感觉有点乱,这样也好,两个我都可以不用,用我自己的,反正已经很乱也不差我多这一个)
接下来看看示例代码,首先搭建开发环境:
我的开发环境是这样的:我不用虚拟机,个人感觉虚拟机性能不好,用的linux服务器搭建的开发环境,此处省略1万字。自己随便搭,搭建起来能用就行
开发板:
Windows电脑上:
稍后看看示例代码:
<未完待续>
