查看: 4878|回复: 2
[原创] [MYD-Y6ULX试用]2.系统初步把玩&联网
  • 签到天数: 310 天
    发表于 2018-3-27 06:37:10 | 显示全部楼层 |阅读模式
    之前由于某些事情比较忙,有一段比较长的时间没有更新了,被可依数次提醒了 这次就来更新了~
    由于板子上面没有带有串口转USB芯片,因此需要外接一个Uart转USB的模块,我使用的是FT232的芯片,总共三根线:Tx、Rx、GND,模块上Rx接板子上Tx;模块上Tx接板子上Rx;
    在软件上我使用SecureCRT软件,这个软件支持多个功能,我用它来与开发板沟通。
    插上外置电源,上电,设置好串口波特率和端口后串口打印出以下内容:
    1. U-Boot 2016.03-mys-6ulx+g9008006 (Jan 16 2018 - 16:55:05 +0800)
    2. CPU:   Freescale i.MX6UL rev1.2 528 MHz (running at 396 MHz)
    3. CPU:   Industrial temperature grade (-40C to 105C) at 40C
    4. Reset cause: POR
    5. Board: MYD-Y6UL 14x14
    6. I2C:   ready
    7. DRAM:  256 MiB
    8. NAND:  256 MiB
    9. MMC:   MMC/SD: Reset never completed.
    10. voltage not supported by controller
    11. Warning: failed to initialize mmc dev 1
    12. FSL_SDHC: 0
    13. *** Warning - bad CRC, using default environment
    14. Display: TFT43AB (480x272)
    15. Video: 480x272x24
    16. In:    serial
    17. Out:   serial
    18. Err:   serial
    19. Net:   Board Net Initialization Failed
    20. No ethernet found.
    21. Normal Boot
    22. Hit any key to stop autoboot:  0
    23. NAND read: device 0 offset 0x500000, size 0xa00000
    24. 10485760 bytes read: OK
    25. NAND read: device 0 offset 0xf00000, size 0x100000
    26. 1048576 bytes read: OK
    27. Kernel image @ 0x80800000 [ 0x000000 - 0x602380 ]
    28. ## Flattened Device Tree blob at 83000000
    29.    Booting using the fdt blob at 0x83000000
    30.    Using Device Tree in place at 83000000, end 8300c1d3
    31. Modify /soc/aips-bus@02000000/bee@02044000:status disabled
    32. ft_system_setup for mx6
    33. Starting kernel ...
    34. Booting Linux on physical CPU 0x0
    35. Linux version 4.1.15-1.2.0+g6ae884d (blackrose@brix4770-debian) (gcc version 5.3.0 (GCC) ) #1 SMP PREEMPT Wed Jan 24 11:04:25 CST 2018
    36. CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
    37. CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    38. Machine model: Freescale i.MX6 UltraLite 14x14 EVK Board
    39. Reserved memory: failed to allocate memory for node 'linux,cma'
    40. Memory policy: Data cache writealloc
    41. PERCPU: Embedded 12 pages/cpu @8fdd3000 s16908 r8192 d24052 u49152
    42. Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
    43. Kernel command line: console=ttymxc0,115200 ubi.mtd=3 root=ubi0:rootfs rootfstype=ubifs mtdparts=gpmi-nand:5m(boot),10m(kernel),1m(dtb),-(rootfs)
    44. PID hash table entries: 1024 (order: 0, 4096 bytes)
    45. Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
    46. Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
    47. Memory: 247644K/262144K available (7847K kernel code, 429K rwdata, 2860K rodata, 424K init, 441K bss, 14500K reserved, 0K cma-reserved, 0K highmem)
    48. Virtual kernel memory layout:
    49.     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
    50.     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
    51.     vmalloc : 0x90800000 - 0xff000000   (1768 MB)
    52.     lowmem  : 0x80000000 - 0x90000000   ( 256 MB)
    53.     pkmap   : 0x7fe00000 - 0x80000000   (   2 MB)
    54.     modules : 0x7f000000 - 0x7fe00000   (  14 MB)
    55.       .text : 0x80008000 - 0x80a7d0f0   (10709 kB)
    56.       .init : 0x80a7e000 - 0x80ae8000   ( 424 kB)
    57.       .data : 0x80ae8000 - 0x80b53720   ( 430 kB)
    58.        .bss : 0x80b56000 - 0x80bc45b8   ( 442 kB)
    59. SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    60. Preemptible hierarchical RCU implementation.
    61.         Additional per-CPU info printed with stalls.
    62.         RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
    63. RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
    64. NR_IRQS:16 nr_irqs:16 16
    65. mxc_clocksource_init 24000000
    66. Switching to timer-based delay loop, resolution 41ns
    67. sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
    68. clocksource mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    69. Console: colour dummy device 80x30
    70. Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
    71. pid_max: default: 32768 minimum: 301
    72. Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    73. Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    74. CPU: Testing write buffer coherency: ok
    75. /cpus/cpu@0 missing clock-frequency property
    76. CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
    77. Setting up static identity map for 0x80008280 - 0x800082d8
    78. Brought up 1 CPUs
    79. SMP: Total of 1 processors activated (48.00 BogoMIPS).
    80. CPU: All CPU(s) started in SVC mode.
    81. devtmpfs: initialized
    82. device-tree: Duplicate name in lcdif@021c8000, renamed to "display#1"
    83. VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
    84. clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    85. pinctrl core: initialized pinctrl subsystem
    86. NET: Registered protocol family 16
    87. DMA: preallocated 256 KiB pool for atomic coherent allocations
    88. cpuidle: using governor ladder
    89. cpuidle: using governor menu
    90. hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
    91. hw-breakpoint: maximum watchpoint size is 8 bytes.
    92. imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
    93. mxs-dma 1804000.dma-apbh: initialized
    94. SCSI subsystem initialized
    95. usbcore: registered new interface driver usbfs
    96. usbcore: registered new interface driver hub
    97. usbcore: registered new device driver usb
    98. i2c i2c-1: IMX I2C adapter registered
    99. i2c i2c-1: can't use DMA
    100. media: Linux media interface: v0.10
    101. Linux video capture interface: v2.00
    102. pps_core: LinuxPPS API ver. 1 registered
    103. pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    104. PTP clock support registered
    105. MIPI CSI2 driver module loaded
    106. Advanced Linux Sound Architecture Driver Initialized.
    107. Switched to clocksource mxc_timer1
    108. NET: Registered protocol family 2
    109. TCP established hash table entries: 2048 (order: 1, 8192 bytes)
    110. TCP bind hash table entries: 2048 (order: 2, 16384 bytes)
    111. TCP: Hash tables configured (established 2048 bind 2048)
    112. UDP hash table entries: 256 (order: 1, 8192 bytes)
    113. UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
    114. NET: Registered protocol family 1
    115. RPC: Registered named UNIX socket transport module.
    116. RPC: Registered udp transport module.
    117. RPC: Registered tcp transport module.
    118. RPC: Registered tcp NFSv4.1 backchannel transport module.
    119. imx rpmsg driver is registered.
    120. Bus freq driver module loaded
    121. futex hash table entries: 256 (order: 2, 16384 bytes)
    122. VFS: Disk quotas dquot_6.6.0
    123. VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    124. NFS: Registering the id_resolver key type
    125. Key type id_resolver registered
    126. Key type id_legacy registered
    127. jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
    128. fuse init (API version 7.23)
    129. io scheduler noop registered
    130. io scheduler deadline registered
    131. io scheduler cfq registered (default)
    132. imx-weim 21b8000.weim: Driver registered.
    133. backlight supply power not found, using dummy regulator
    134. MIPI DSI driver module loaded
    135. MIPI DSI driver module loaded
    136. 21c8000.lcdif supply lcd not found, using dummy regulator
    137. mxsfb 21c8000.lcdif: failed to find mxc display driver
    138. Console: switching to colour frame buffer device 60x34
    139. mxsfb 21c8000.lcdif: initialized
    140. imx-sdma 20ec000.sdma: no event needs to be remapped
    141. imx-sdma 20ec000.sdma: loaded firmware 3.3
    142. imx-sdma 20ec000.sdma: initialized
    143. 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 20, base_baud = 5000000) is a IMX
    144. console [ttymxc0] enabled
    145. 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 232, base_baud = 5000000) is a IMX
    146. 21f0000.serial: ttymxc3 at MMIO 0x21f0000 (irq = 233, base_baud = 5000000) is a IMX
    147. imx sema4 driver is registered.
    148. [drm] Initialized drm 1.1.0 20060810
    149. [drm] Initialized vivante 1.0.0 20120216 on minor 0
    150. brd: module loaded
    151. loop: module loaded
    152. nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xda
    153. nand: Micron MT29F2G08ABAEAWP
    154. nand: 256 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
    155. gpmi-nand 1806000.gpmi-nand: enable the asynchronous EDO mode 5
    156. Bad block table found at page 131008, version 0x01
    157. Bad block table found at page 130944, version 0x01
    158. 4 cmdlinepart partitions found on MTD device gpmi-nand
    159. Creating 4 MTD partitions on "gpmi-nand":
    160. 0x000000000000-0x000000500000 : "boot"
    161. 0x000000500000-0x000000f00000 : "kernel"
    162. 0x000000f00000-0x000001000000 : "dtb"
    163. 0x000001000000-0x000010000000 : "rootfs"
    164. gpmi-nand 1806000.gpmi-nand: driver registered.
    165. CAN device driver interface
    166. flexcan 2094000.can: device registered (reg_base=92a48000, irq=29)
    167. 20b4000.ethernet supply phy not found, using dummy regulator
    168. pps pps0: new PPS source ptp0
    169. fec 20b4000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
    170. fec 20b4000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: fe:28:c5:ea:99:96
    171. libphy: fec_enet_mii_bus: probed
    172. fec 20b4000.ethernet eth0: registered PHC device 0
    173. 2188000.ethernet supply phy not found, using dummy regulator
    174. pps pps1: new PPS source ptp1
    175. fec 2188000.ethernet (unnamed net_device) (uninitialized): Invalid MAC address: 00:00:00:00:00:00
    176. fec 2188000.ethernet (unnamed net_device) (uninitialized): Using random MAC address: da:10:0f:22:44:0d
    177. fec 2188000.ethernet eth1: registered PHC device 1
    178. PPP generic driver version 2.4.2
    179. PPP BSD Compression module registered
    180. PPP Deflate Compression module registered
    181. PPP MPPE Compression module registered
    182. NET: Registered protocol family 24
    183. SLIP: version 0.8.4-NET3.019-NEWTTY (dynamic channels, max=256) (6 bit encapsulation enabled).
    184. CSLIP: code copyright 1989 Regents of the University of California.
    185. SLIP linefill/keepalive option.
    186. ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    187. ehci-mxc: Freescale On-Chip EHCI Host driver
    188. usbcore: registered new interface driver usb-storage
    189. usbcore: registered new interface driver usbserial
    190. usbcore: registered new interface driver usbserial_generic
    191. usbserial: USB Serial support registered for generic
    192. usbcore: registered new interface driver option
    193. usbserial: USB Serial support registered for GSM modem (1-port)
    194. usbcore: registered new interface driver usb_ehset_test
    195. 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
    196. 2184000.usb supply vbus not found, using dummy regulator
    197. 2184200.usb supply vbus not found, using dummy regulator
    198. ci_hdrc ci_hdrc.1: EHCI Host Controller
    199. ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
    200. ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
    201. hub 1-0:1.0: USB hub found
    202. hub 1-0:1.0: 1 port detected
    203. mousedev: PS/2 mouse device common for all mice
    204. input: 20cc000.snvs:snvs-powerkey as /devices/platform/soc/2000000.aips-bus/20cc000.snvs/20cc000.snvs:snvs-powerkey/input/input0
    205. tp reset gpio=130
    206. msg ft5x0x_i2c_rxdata i2c read error: -5
    207. ft5x0x read ID error!
    208. ft5x06_ts: probe of 1-0038 failed with error 161
    209. ft5x0x_ts_init successful
    210. input: iMX6UL TouchScreen Controller as /devices/platform/soc/2000000.aips-bus/2040000.tsc/input/input1
    211. snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-r as rtc0
    212. i2c /dev entries driver
    213. IR NEC protocol handler initialized
    214. IR RC5(x/sz) protocol handler initialized
    215. IR RC6 protocol handler initialized
    216. IR JVC protocol handler initialized
    217. IR Sony protocol handler initialized
    218. IR SANYO protocol handler initialized
    219. IR Sharp protocol handler initialized
    220. IR MCE Keyboard/mouse protocol handler initialized
    221. IR XMP protocol handler initialized
    222. pxp-v4l2 pxp_v4l2: initialized
    223. usbcore: registered new interface driver uvcvideo
    224. USB Video Class driver (1.1.1)
    225. sdhci: Secure Digital Host Controller Interface driver
    226. sdhci: Copyright(c) Pierre Ossman
    227. sdhci-pltfm: SDHCI platform and OF driver helper
    228. /soc/aips-bus@02100000/usdhc@02190000: voltage-ranges unspecified
    229. sdhci-esdhc-imx 2190000.usdhc: could not get ultra high speed state, work on normal mode
    230. sdhci-esdhc-imx 2190000.usdhc: Got CD GPIO
    231. sdhci-esdhc-imx 2190000.usdhc: No vqmmc regulator found
    232. mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
    233. /soc/aips-bus@02100000/usdhc@02194000: voltage-ranges unspecified
    234. sdhci-esdhc-imx 2194000.usdhc: could not get ultra high speed state, work on normal mode
    235. sdhci-esdhc-imx 2194000.usdhc: No vmmc regulator found
    236. sdhci-esdhc-imx 2194000.usdhc: No vqmmc regulator found
    237. mmc0: host does not support reading read-only switch, assuming write-enable
    238. mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
    239. caam 2140000.caam: Entropy delay = 3200
    240. usb 1-1: new high-speed USB device number 2 using ci_hdrc
    241. mmc0: new high speed SDHC card at address 0001
    242. mmcblk0: mmc0:0001 SD16G 14.5 GiB
    243. caam 2140000.caam: Instantiated RNG4 SH0
    244. mmcblk0: p1
    245. mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
    246. caam 2140000.caam: Instantiated RNG4 SH1
    247. caam 2140000.caam: device ID = 0x0a16030000000000 (Era -524)
    248. caam 2140000.caam: job rings = 3, qi = 0
    249. mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    250. mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
    251. mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
    252. mmc1: queuing unknown CIS tuple 0x80 (10 bytes)
    253. mmc1: new high speed SDIO card at address 0001
    254. hub 1-1:1.0: USB hub found
    255. hub 1-1:1.0: 4 ports detected
    256. caam algorithms registered in /proc/crypto
    257. caam_jr 2141000.jr0: registering rng-caam
    258. platform caam_sm: blkkey_ex: 8 keystore units available
    259. platform caam_sm: 64-bit clear key:
    260. platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
    261. platform caam_sm: 64-bit black key:
    262. platform caam_sm: [0000] b9 ff 93 bd b0 2f ee a1
    263. platform caam_sm: [0008] 6d 28 1b 8f 43 e8 3b 3b
    264. platform caam_sm: 128-bit clear key:
    265. platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
    266. platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
    267. platform caam_sm: 128-bit black key:
    268. platform caam_sm: [0000] 5b 0a 1a a0 15 2d b1 ec
    269. platform caam_sm: [0008] 79 ce b9 6f e9 c5 b1 b7
    270. platform caam_sm: 192-bit clear key:
    271. platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
    272. platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
    273. platform caam_sm: [0016] 10 11 12 13 14 15 16 17
    274. platform caam_sm: 192-bit black key:
    275. platform caam_sm: [0000] 81 c1 be a5 82 ae 8f bf
    276. platform caam_sm: [0008] db 12 cb 37 27 91 61 9e
    277. platform caam_sm: [0016] 76 27 87 c9 99 e1 80 50
    278. platform caam_sm: [0024] d4 37 01 d8 b8 d3 6d de
    279. platform caam_sm: 256-bit clear key:
    280. platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
    281. platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
    282. platform caam_sm: [0016] 10 11 12 13 14 15 16 17
    283. platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
    284. platform caam_sm: 256-bit black key:
    285. platform caam_sm: [0000] 49 5b a6 ae 18 92 4d 4d
    286. platform caam_sm: [0008] a3 88 ac 79 9e fe f0 00
    287. platform caam_sm: [0016] 45 55 f5 d9 6e 68 a5 de
    288. platform caam_sm: [0024] d7 1d e6 94 49 e8 d6 30
    289. platform caam_sm: 64-bit unwritten blob:
    290. platform caam_sm: [0000] 00 00 00 00 00 00 00 00
    291. platform caam_sm: [0008] 00 00 00 00 00 00 00 00
    292. platform caam_sm: [0016] 00 00 00 00 00 00 00 00
    293. platform caam_sm: [0024] 00 00 00 00 00 00 00 00
    294. platform caam_sm: [0032] 00 00 00 00 00 00 00 00
    295. platform caam_sm: [0040] 00 00 00 00 00 00 00 00
    296. platform caam_sm: [0048] 00 00 00 00 00 00 00 00
    297. platform caam_sm: [0056] 00 00 00 00 00 00 00 00
    298. platform caam_sm: [0064] 00 00 00 00 00 00 00 00
    299. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
    300. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
    301. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
    302. platform caam_sm: 128-bit unwritten blob:
    303. platform caam_sm: [0000] 00 00 00 00 00 00 00 00
    304. platform caam_sm: [0008] 00 00 00 00 00 00 00 00
    305. platform caam_sm: [0016] 00 00 00 00 00 00 00 00
    306. platform caam_sm: [0024] 00 00 00 00 00 00 00 00
    307. platform caam_sm: [0032] 00 00 00 00 00 00 00 00
    308. platform caam_sm: [0040] 00 00 00 00 00 00 00 00
    309. platform caam_sm: [0048] 00 00 00 00 00 00 00 00
    310. platform caam_sm: [0056] 00 00 00 00 00 00 00 00
    311. platform caam_sm: [0064] 00 00 00 00 00 00 00 00
    312. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
    313. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
    314. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
    315. platform caam_sm: 196-bit unwritten blob:
    316. platform caam_sm: [0000] 00 00 00 00 00 00 00 00
    317. platform caam_sm: [0008] 00 00 00 00 00 00 00 00
    318. platform caam_sm: [0016] 00 00 00 00 00 00 00 00
    319. platform caam_sm: [0024] 00 00 00 00 00 00 00 00
    320. platform caam_sm: [0032] 00 00 00 00 00 00 00 00
    321. platform caam_sm: [0040] 00 00 00 00 00 00 00 00
    322. platform caam_sm: [0048] 00 00 00 00 00 00 00 00
    323. platform caam_sm: [0056] 00 00 00 00 00 00 00 00
    324. platform caam_sm: [0064] 00 00 00 00 00 00 00 00
    325. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
    326. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
    327. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
    328. platform caam_sm: 256-bit unwritten blob:
    329. platform caam_sm: [0000] 00 00 00 00 00 00 00 00
    330. platform caam_sm: [0008] 00 00 00 00 00 00 00 00
    331. platform caam_sm: [0016] 00 00 00 00 00 00 00 00
    332. platform caam_sm: [0024] 00 00 00 00 00 00 00 00
    333. platform caam_sm: [0032] 00 00 00 00 00 00 00 00
    334. platform caam_sm: [0040] 00 00 00 00 00 00 00 00
    335. platform caam_sm: [0048] 00 00 00 00 00 00 00 00
    336. platform caam_sm: [0056] 00 00 00 00 00 00 00 00
    337. platform caam_sm: [0064] 00 00 00 00 00 00 00 00
    338. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
    339. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
    340. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
    341. platform caam_sm: 64-bit black key in blob:
    342. platform caam_sm: [0000] 31 72 7f d8 e6 f1 68 76
    343. platform caam_sm: [0008] e7 fb 06 d5 05 92 24 0d
    344. platform caam_sm: [0016] 2e 88 b6 75 6a f9 aa 75
    345. platform caam_sm: [0024] 79 c7 d4 88 09 34 6c d8
    346. platform caam_sm: [0032] c4 45 26 da ba f3 1b f6
    347. platform caam_sm: [0040] 1f 04 3e e2 df 89 22 58
    348. platform caam_sm: [0048] 13 39 fb a2 06 ce 95 7a
    349. platform caam_sm: [0056] 00 00 00 00 00 00 00 00
    350. platform caam_sm: [0064] 00 00 00 00 00 00 00 00
    351. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
    352. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
    353. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
    354. platform caam_sm: 128-bit black key in blob:
    355. platform caam_sm: [0000] cc d1 85 82 25 3a 53 c7
    356. platform caam_sm: [0008] 07 01 77 06 ec 9d c3 aa
    357. platform caam_sm: [0016] 58 f3 aa 59 f9 fd bb 2e
    358. platform caam_sm: [0024] 36 be c1 43 35 1b 88 10
    359. platform caam_sm: [0032] a7 09 35 88 13 0e ab 8b
    360. platform caam_sm: [0040] 73 ea 96 7b 33 05 d1 cc
    361. platform caam_sm: [0048] 5b 63 2c 68 33 52 6a f4
    362. platform caam_sm: [0056] 8f 81 05 ef f4 df 44 be
    363. platform caam_sm: [0064] 00 00 00 00 00 00 00 00
    364. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
    365. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
    366. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
    367. platform caam_sm: 192-bit black key in blob:
    368. platform caam_sm: [0000] 55 87 f6 e2 86 ac 00 7c
    369. platform caam_sm: [0008] 3e 26 a7 3f af e7 0e 52
    370. platform caam_sm: [0016] c4 d8 2f ef c0 4e 0d 2c
    371. platform caam_sm: [0024] 6a 5d 75 e0 4d 50 b1 45
    372. platform caam_sm: [0032] 0a 94 f0 c5 b5 f9 87 77
    373. platform caam_sm: [0040] 9b b7 ed 47 97 96 91 c3
    374. platform caam_sm: [0048] 4e 45 b5 8a 28 0b 80 c9
    375. platform caam_sm: [0056] 1c f7 ef 77 48 2e 3e 05
    376. platform caam_sm: [0064] c7 13 3d 4c ca 2d 40 22
    377. platform caam_sm: [0072] 00 00 00 00 00 00 00 00
    378. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
    379. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
    380. platform caam_sm: 256-bit black key in blob:
    381. platform caam_sm: [0000] b8 d2 d6 d2 2e b7 e3 e0
    382. platform caam_sm: [0008] 1e 63 0f 07 56 24 43 43
    383. platform caam_sm: [0016] f6 49 02 f2 6e 99 59 1f
    384. platform caam_sm: [0024] 55 26 15 f7 23 06 ad b7
    385. platform caam_sm: [0032] db b8 01 e1 56 39 66 ea
    386. platform caam_sm: [0040] 85 e1 ff 38 94 6a fe 77
    387. platform caam_sm: [0048] 7d e8 d7 7b 19 e2 43 e4
    388. platform caam_sm: [0056] 1d 2f 01 02 2a 0f 1b 71
    389. platform caam_sm: [0064] 2c dd f6 11 85 5d 53 26
    390. platform caam_sm: [0072] b0 74 1d 54 2b 33 c8 9d
    391. platform caam_sm: [0080] 00 00 00 00 00 00 00 00
    392. platform caam_sm: [0088] 00 00 00 00 00 00 00 00
    393. platform caam_sm: restored 64-bit black key:
    394. platform caam_sm: [0000] 51 e4 9e ad 62 fa d6 88
    395. platform caam_sm: [0008] 18 40 2a c9 21 41 8e 42
    396. platform caam_sm: restored 128-bit black key:
    397. platform caam_sm: [0000] 5b 0a 1a a0 15 2d b1 ec
    398. platform caam_sm: [0008] 79 ce b9 6f e9 c5 b1 b7
    399. platform caam_sm: restored 192-bit black key:
    400. platform caam_sm: [0000] 81 c1 be a5 82 ae 8f bf
    401. platform caam_sm: [0008] db 12 cb 37 27 91 61 9e
    402. platform caam_sm: [0016] 5d 62 5f b7 3e df 66 78
    403. platform caam_sm: [0024] 79 25 fb ee 75 c0 c8 4d
    404. platform caam_sm: restored 256-bit black key:
    405. platform caam_sm: [0000] 49 5b a6 ae 18 92 4d 4d
    406. platform caam_sm: [0008] a3 88 ac 79 9e fe f0 00
    407. platform caam_sm: [0016] 45 55 f5 d9 6e 68 a5 de
    408. platform caam_sm: [0024] d7 1d e6 94 49 e8 d6 30
    409. snvs-secvio 20cc000.caam-snvs: can't get snvs clock
    410. snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
    411. usbcore: registered new interface driver usbhid
    412. usbhid: USB HID core driver
    413. usbcore: registered new interface driver snd-usb-audio
    414. 1-001a supply DCVDD not found, using dummy regulator
    415. 1-001a supply DBVDD not found, using dummy regulator
    416. 1-001a supply AVDD not found, using dummy regulator
    417. 1-001a supply CPVDD not found, using dummy regulator
    418. 1-001a supply MICVDD not found, using dummy regulator
    419. wm8904 1-001a: revision A
    420. fsl-asrc 2034000.asrc: driver registered
    421. imx-wm8904 sound: wm8904-hifi <-> 202c000.sai mapping ok
    422. imx-wm8904 sound: snd-soc-dummy-dai <-> 2034000.asrc mapping ok
    423. imx-wm8904 sound: wm8904-hifi <-> 202c000.sai mapping ok
    424. NET: Registered protocol family 26
    425. NET: Registered protocol family 10
    426. sit: IPv6 over IPv4 tunneling driver
    427. NET: Registered protocol family 17
    428. can: controller area network core (rev 20120528 abi 9)
    429. NET: Registered protocol family 29
    430. can: raw protocol (rev 20120528)
    431. can: broadcast manager protocol (rev 20120528 t)
    432. can: netlink gateway (rev 20130117) max_hops=1
    433. 8021q: 802.1Q VLAN Support v1.8
    434. Key type dns_resolver registered
    435. ubi0: attaching mtd3
    436. random: nonblocking pool is initialized
    437. ubi0: scanning is finished
    438. ubi0: attached mtd3 (name "rootfs", size 240 MiB)
    439. ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
    440. ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
    441. ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
    442. ubi0: good PEBs: 1916, bad PEBs: 4, corrupted PEBs: 0
    443. ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
    444. ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 1928584424
    445. ubi0: available PEBs: 0, total reserved PEBs: 1916, PEBs reserved for bad PEB handling: 36
    446. ubi0: background thread "ubi_bgt0d" started, PID 140
    447. input: gpio-keys as /devices/platform/gpio-keys/input/input2
    448. snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 1970-01-01 00:00:02 UTC (2)
    449. can-3v3: disabling
    450. ALSA device list:
    451.   #0: wm8904-audio
    452. UBIFS (ubi0:0): recovery needed
    453. UBIFS (ubi0:0): recovery deferred
    454. UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs", R/O mode
    455. UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
    456. UBIFS (ubi0:0): FS size: 236683264 bytes (225 MiB, 1864 LEBs), journal size 11808768 bytes (11 MiB, 93 LEBs)
    457. UBIFS (ubi0:0): reserved for root: 4952683 bytes (4836 KiB)
    458. UBIFS (ubi0:0): media format: w4/r0 (latest is w4/r0), UUID 45A5F12D-44F2-46A4-B1FA-098586D6E5BF, small LPT model
    459. VFS: Mounted root (ubifs filesystem) readonly on device 0:14.
    460. devtmpfs: mounted
    461. Freeing unused kernel memory: 424K (80a7e000 - 80ae8000)
    462. INIT: version 2.88 booting
    463. Starting udev
    464. udevd[176]: starting version 3.1.5
    465. UBIFS (ubi0:0): completing deferred recovery
    466. UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 211
    467. UBIFS (ubi0:0): deferred recovery completed
    468. ov2659 1-0030: Sensor soft reset failed
    469. bootlogd: cannot allocate pseudo tty: No such file or directory
    470. brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Apr 22 2013 14:50:00 version 5.90.195.89.6 FWID 01-b30a427d
    471. brcmfmac: brcmf_cfg80211_reg_notifier: not a ISO3166 code
    472. FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    473. ALSA: Restoring mixer settings...
    474. Wed Jan 24 04:45:21 UTC 2018
    475. INIT: Entering runlevel: 5
    476. Configuring network interfaces... fec 20b4000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=20b4000.ethernet:01, irq=-1)
    477. IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    478. udhcpc (v1.24.1) started
    479. Sending discover...
    480. Sending discover...
    481. Sending discover...
    482. No lease, forking to background
    483. done.
    484. Starting system message bus: dbus.
    485. Starting OpenBSD Secure Shell server: sshd
    486. done.
    487. Starting rpcbind daemon...done.
    488. Starting advanced power management daemon: No APM support in kernel
    489. (failed.)
    490. Starting syslogd/klogd: done
    491. * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
    492.    ...done.
    493. Starting Telephony daemon
    494. Starting Linux NFC daemon
    495. Running local boot scripts (/etc/rc.local).
    496. xres = 480, yres = 272
    497. Freescale i.MX Release Distro 4.1.15-2.0.1 myd-y6ul14x14 /dev/ttymxc0
    看起来启动成功,采用的是uboot+Freescale定制系统,基于Debian修改的,内存为256Mb,Nand Flash也为256Mb。登录名为root,没有设置密码~
    既然上手自然要看一下原装系统的参数:
    输入以下参数查看Linux内核版本
    1. cat /proc/version
    输入以下参数查看CPU参数
    1. cat /proc/cpuinfo
    ARMv7处理器,A7架构有点老,但是架构成熟,性价比高。
    输入以下参数查看分区情况
    1. df -h
    就只有一个256Mb分区,用了近30%,最下面那个mmcblk0p1是我插进去的16G MicroSD卡。
    输入以下参数查看内存情况
    1. cat /proc/meminfo
    作为一个有WIFI的板子,查看完参数之后就一定要连接WIFI,在配置WIFI过程中,需要使用Uart接口进行配置。别忘了在配置WIFI前装好随板子附带的WIFI天线。
    在命令行中输入以下生成对应的PSK
    1. cd ~
    其中myWIFI替换成你要连接WIFI网络的名字,myPassWord替换成WIFI网络密码。
    然后输入以下命令查看有没有生成对应的PSK:
    1. cat wifi.conf
    此时屏幕会打印出wifi.conf文件内容,看一下WIFI名字和密码对不对,PSK有没有生成就好了。此时这个wifi.conf配置文件已经保存在~中,即是用户文件夹中,下一次连接wifi就不需要再次生成了,直接导入进去。
    然后接着输入以下命令导入进去,连接WIFI网络
    1. wpa_supplicant -D wext -B -i wlan0 -c wifi.conf
    在连接了WIFI还不能上网,还需要向路由器DHCP取分配的IP地址和其他网络参数。
    输入以下命令进行获取DHCP信息
    1. udhcpc -b -i wlan0 -R
    到此步应该就成功了
    输入以下命令查看是否获取成功:
    1. ifconfig wlan0
    既然连上网了,先来测试一下是否能够ping通外网地址:
    输入以下命令来测试一下是否能正确获取和链接爱板网的ip地址吧~
    1. ping -c 5 www.eeboard.com
    Snipaste_2018-03-27_05-40-07.png 如果没问题的话应该如图所示,爱板网网速还是挺快的~
    既然能ping通,接下来就试试telnet功能吧,由于telnet没有加密,因此安全性并不是很好,现在基本淘汰了,但是telnet还有一个很好玩的地方,可以用来看“电影”,整个“电影”由字符串组成,主题是星战,不得不佩服国外作者的耐心~
    输入以下命令即可观看:
    1. telnet towel.blinkenlights.nl
    这个一直看就行,不用操作,退出按Ctrl+C即可
    联网已经搞定了,能够联网对于我们来说就很方便了,可以通过WIFI来操作,我们可以通过一个加密的telnet来连接开发板来操作,这样就不需要Uart转USB的模块了,开发也方便多了。我所采用的是SSH2协议,SSH2是经过SSL加密处理的,更加安全,SecureCRT软件也支持该种方式进行登录。
    在开始配置之前,需要查看路由器分配给开发板的IP地址,输入:
    1. ifconfig wlan0
    查看ip地址一栏,并且记下来。然后设置SecureCRT来连接,hostname为之前查看的开发板ip地址,端口为22。
    对于Linux用户来说,Linux也支持SSH登录方式,没有安装的可以去下载安装OpenSSH。
    这里以Ubuntu为例,Ubuntu本身预装了,只需输入以下命令:
    1. ssh root@192.168.1.2
    注意,192.168.1.2替换为你之前查到的开发板ip地址。
    对于想通过WIFI来传输文件的用户,SecureCRT支持SFTP功能,来进行文件安全加密的互传。但是启动失败了,经查是米尔的板子安装了OPENSSH,但是并没有安装SFTP功能,缺少文件,所以没有进行。
    不过,对于一般用户来说,特别是在内网中使用的话,使用简易没加密版的TFTP也可以的。米尔预装的系统中有TFTP功能,可以提供简单的文件互传功能。
    对于Linux用户,需要安装tftp-server功能,这里就不说了~
    对于Windows用户,系统已经自带了TFTP功能,但是很可能没有安装,需要到控制面板中安装一下。如果不想安装,可以推荐使用一个绿色版小型TFTP软件——tftpd64(32位为tftpd32),自带Client和Server模式,最重要的是占空间小。绿色包我放在论坛上,直接运行不用安装!
    tftpd64.460.zip (517.06 KB, 下载次数: 1, 售价: 1 与非币)
    发表于 2018-3-27 09:03:35 | 显示全部楼层
    哎,毕竟可依漂亮可爱又认真负责
  • 签到天数: 310 天
     楼主| 发表于 2018-3-27 09:44:28 | 显示全部楼层
    ky123 发表于 2018-3-27 09:03
    哎,毕竟可依漂亮可爱又认真负责
    可依还时刻不忘自夸
    GMT+8, 2024-5-7 11:27 , Processed in 0.141564 second(s), 21 queries , MemCache On.
