回答
收藏
MSP430 USB记忆棒F2012板
#板卡评测 #板卡评测 1112 人阅读 | 0 人回复 | 2012-08-02
描述
eZ430-T2012 包含三个MSP430F2012 基础上的目标板,用于 eZ430-F2013 开发工具。eZ430开发工具提供了一个用于MSP430F2012目标板的实时调试和编程接口, 配置了方便使用的 IAR Embedded Workbench Integrated Development Environment (IDE).The T2012 can be used to develop your personal project or to evaluate the MSP430 MCU. The T2012 gives you all the same capabilities and peripherals of the MSP430F2013 on the eZ430, but includes a high-speed, 8-channel 10-bit ADC.The ECCN (Export Control Classification Number) classification for this tool will be the same as the included microcontrollers. To find ECCN information for a microcontroller, see the datasheet for that device.Any use made of Texas Instruments (TI) classifications, whether it be ECCNs or HTS, is without recourse to TI and at the user’s risk. HTS and export classifications are subject to change. Your company, as the exporter of record, is responsible for determining the correct classification of any item at the time of export. Any HTS or export classification by TI is for TI’s internal use only and shall not be construed as a representation or warranty regarding the proper export classification nor relied upon to make licensing determinations.
 特性
  • 3 eZ430-T2012 target boards with a 4-pin connector to fit the eZ430-F2013 USB Development Tool
  • MSP430F2012-based target board
  • Fully accessible pins
  • LED indicator
下载连接:
MSP430 超低功耗微处理器手册--选择指南
