回答
收藏
LPC315x 系列评估板
#板卡评测 #板卡评测 862 人阅读 | 0 人回复 | 2012-08-03
The OM110129,598 is a Embedded Artist NXP LPC315x Series Evaluation Board. The LPC315x series runs at 180 MHz and adds a stereo audio CODEC with class AB headphone amplifier, a Power Supply Unit (PSU), a low-power real-time clock, and a Li-ion battery charger.
With an extensive and enhanced feature set, the LPC313x ARM9 microcontrollers are ideal for a wide range of applications, including consumer applications such as advanced remote controls, language translators, A/V home devices, mobile and PC accessories, industrial applications such as industrial controls, factory and building automation, POS systems, bar code readers, e-Metering, security systems, Smart Cards with USB flash and power management systems, medical application such as portable diagnostics and pump and flow metering devices, automotive applications such as engine diagnostics, fleet management and in-dash audio, communications application such as I/O communication and network controllers, and instrumentation and testing applications.
Features:
  • NXP's most advanced microcontrollers
  • With speeds of up to 266 MHz, the NXP LPC3000 family supports Linux and WinCE and is ideal for a wide range of applications in consumer, medical, industrial, automotive and networking
  • 32-bit ARM9 cores
  • Supported by a comprehensive set of software and hardware design tools, the LH7A family makes it easy to create everything from cost-conscious consumer systems to advanced systems with media-rich environments
  • Speeds in excess of 200 MHz
  • Code Read Protection mechanism to safeguard user code
  • 90 nm technology
  • Up to 32 kB of zero wait-state Flash
  • Real-time clock with 32-kHz crystal and battery back-up pins
  • Up to 8 kB of SRAM
Applications:
  • Serial communications protocol converters
  • Handheld card readers
  • Distributor access and security control
  • ZigBee
