回答
收藏
Stellaris AC 感应电机参考设计套件
#板卡评测 #板卡评测 975 人阅读 | 0 人回复 | 2012-08-06
描述
Stellaris® AC 感应电机参考设计套件(RDK) 包含设计和开发所需的所有硬件和软件,并整合步进电机应用。The AC Induction Motor RDK combines the strength and flexibility of Stellaris microcontrollers with Fairchild Semiconductor's power modules to create an advanced variable speed AC motor control design that has been carefully engineered for performance, cost, and flexibility. AC induction motors are particularly suited for use in major home appliances (refrigerators, dishwashers, washing machines, and dryers), residential and light commercial HVAC systems, and three-phase industrial motor drives.
特性
The AC Induction Motor Reference Design Kit contains Luminary Micro's new feature-rich Stellaris LM3S818 microcontroller designed for motion control applications, Fairchild Semiconductor's FSBS10CH60 power module, a Selni three-phase appliance AC motor, a graphical control program for Windows™, and accompanying cables, source code, and documentation. The ACIM RDK takes advantage of the integrated features of the Stellaris microcontroller and the processing power of the ® Cortex™-M3 core to implement both sine wave control and energy-efficient space vector modulation control. The graphical control program allows you to experiment with varying drive parameters and observe the effect on motor performance.The AC Induction Motor Reference Design Kit includes the following product features:
  • Source code for main control algorithms including space-vector modulation and sine control
  • Advanced motor control for three-phase and single-phase AC induction motors
  • Accelerated integration process through a flexible platform
  • Active braking circuit
  • Active in-rush control circuit
  • Easily change line filter, bus capacitors, and JTAG interface
  • Accurate current sensing using split low-side current sensing
  • Several isolated control input options including:
    • Virtual COM port through integrated USB port
    • Windows GUI application for configuration, control, and monitoring
    • Logic-level serial port
    • Speed potentiometer and mode switch
    • Speed and position monitoring using quadrature encoder/tachometer input
  • Electrically isolated JTAG port for software debugging
  • Bootloader for firmware upgrades over serial port
套件内容
The AC Induction Motor Reference Design Kit ships with everything needed to evaluate AC induction motor control including:
  • Main control circuit board with a factory-installed heatsink
  • 3-phase Selni appliance AC motor (0-20000 rpm)
  • Power cables
  • USB cable
  • Graphical control program for Windows™ on CD
  • Design Kit CD containing Quickstart Guide, User’s Manual, Software Reference Manual, source code, BOM, schematics, and Gerber files
下载连接:
Stellaris LM3S818 AC 感应电机参考设计套件用户指南
Stellaris LM3S818AC 感应电机开发板数据手册
