回答
收藏
ST7MDT20J-TEB仿真板
#板卡评测 #板卡评测 839 人阅读 | 0 人回复 | 2012-08-07
描述ST7-EMU3系列仿真器是第三代高端ST7仿真器。EMU3系列仿真器提供了一个先进的功能齐全的调试器,设计用于加速ST7单片机的复杂软件开发。 在ST7的可视化开发( STVD7 )和ST7可视化编程( STVP7 )的结合,它们提供应用程序从头到尾的开发 - 从建设和调试应用程序到ST7的编程。
The EMU3 series emulators deliver start-to-finish control by providing both emulation and In-Circuit Communication (ICC) configurations from a single platform.In the emulation configuration, the EMU3 probe and STVD7 software allow debugging while connected an application board in place of the target ST7. This configuration offers the most complete range of debugging features, including trace, advanced breakpoints and performance analysis. In addition, the EMU3 comes with all the adapters and connectors to connect to the application board in place of the target ST7.The ICC configuration allows In-Circuit Debugging (ICD) of the application while it runs on the ST7 that is installed on your application board. Once debugging is completed, the ICC configuration allows In-Circuit Programming (ICP) of ST7 Flash microcontrollers on your application board or an ST7 Socket Board.
关键特性
  • Emulation Features
    • Unlimited breakpoints with counter and condition
    • Two output triggers
    • Nine external input triggers
    • 256K real-time trace recording with timestamp
    • Memory read/write on the fly
    • Low voltage emulation from 1.8 to 5.5 V
    • Programmable clock frequency from 32 KHz up to 16 MHz
    • Performance Analysis
    • Four-level logic sequencer that allows you to perform specific actions such as:
      • Stop program execution
      • Start/stop trace recording,
      • Record a snapshot in the trace,
      • Output signals via the two output triggers
      These actions can be coordinated with the occurrence of a specific event or a series of events such as:
      • an event at an address or range of addresses,
      • a specific data value with bit mask,
      • a read, write or read/write access,
      • stack operation access
      ...or any combination of these.
下载连接:
ST7MDT10-TEB仿真板简介
ST7MDT20J-TEB仿真板用户指南
