回答
收藏
dsPIC33F和PIC24H 开发板
#板卡评测 #板卡评测 631 人阅读 | 0 人回复 | 2012-08-13
Microstick dsPIC33F 和 PIC24H 设备旨在给设计师为在为设计师提供一个易于使用的、 经济的发展环境为 16 位 dsPIC ® 数字信号控制器和 PIC ® 微控制器提供一个易于使用的、 经济的发展环境。Microstick provides all you need to get started at a very low cost. It has an integrated programmer / debugger. It can be used stand-alone or plugged into a prototyping board for extremely flexible development. The device under test is socketed for easy change-out, and Microchip’s MPLAB® Integrated Development Environment supports Microstick. It has never been more affordable to get started with Microchip 16-bit devices!Key Features:
  • Low Cost 16-bit board – Priced at $24.99 at Microchip Direct
  • Integrated USB programmer / debugger – No external debugger required
  • USB Powered – Ease of use, No external power required
  • Socketed dsPIC/PIC24 – Flexible, Easy device replacement
  • 0.025” Pin headers – Enables plug-in to Breadboard with room for jumper wires
  • Easy access to all device signals for probing
  • Small size - Smaller than a stick of gum at 20 x76mm – Easily Portable
  • On board debug LED, Utility LED and Reset Switch
  • Free demo code
下载连接:
dsPIC33F和PIC24H 开发板资料
