回答
收藏
16位XLP开发板
#板卡评测 #板卡评测 954 人阅读 | 0 人回复 | 2012-08-14
16位XLP开发板核心是eXtreme Low Powerin思想.  此开发板作为1个真实的低功率的开发平台,它的待机电流低至20nA。The board is suitable for prototyping many low power applications including RF sensors, data loggers, temperature sensors, electronic door locks, metering sensors, remote controls, security sensors, smart cards, and energy harvesting. The PICtail™ interface supports Microchip’s extensive line of daughter cards for easy evaluation of your next low power application.This low cost board is the ideal complement to the MPLAB® PICkit 3 or ICD 3 debugger and programmer realizing a fully-featured, economical, PIC24 development environment.16位XLP开发板特性:
● PIC24F16KA102 (16KB Flash, 28-pins, XLP Device with 20nA Deep Sleep current )● Supports other PIC24F devices in 20 or 28-pins● Current measurement terminals allow device or board level current measurements (optional XLP Current Measurement Cable available)● PICtail ™ daughter board connector for connection to expansion boards such as RF, SD/MMC Cards, Speech Playback and more● mTouch™ capacitive sensing buttons for user input● Expansion connector accessing full device pin-out and breadboard prototype area● Convenient connections for MPLAB PICkit 3, ICD 3 or REAL ICE for in-circuit programming and debugging● USB interface for power and PC communication● 24AA256 Low Power (100nA Sleep, 1.7V Vdd) SPI serial-EEPROM● Crystal oscillators for main clock and Real-time Clock and Calendar● Potentiometer (connected to 10-bit A/D, analog input channel)● Analog output temperature sensor and CTMU based diode temperature sensor● LEDs for indication● Optional RS-232 port (not populated)● Power Options: AAA, CR2032, Energy Harvesting, USB, External, or 9V power supply
下载连接:
16位XLP开发板电路图
16位XLP开发板用户指南
