回答
收藏
PICDEM MC LV开发板
#板卡评测 #板卡评测 1531 人阅读 | 0 人回复 | 2012-08-15
PICDEM MC LV 开发板提供了经济高效的方案,用于评估以及开发感应或无传感器无刷直流(BLDC) 电机控制应用。该开发板支持微芯28-Pin PIC18F微控制器 和 dsPIC30F DSCs。开发板能够控制额定 48V 2.2A的电机。The development board also comes with two pre-programmed, Flash-based devices for easy development: the PIC18F2431 device will populate the 28-pin socket and the dsPIC30F3010 will ship in a separate sample box. Additionally, the board comes with a free Motor Control Graphical User Interface (MC-GUI) which can set and modify all motor parameters. Custom programming and in-circuit debugging are facilitated with the ICD connector for Microchip’s MPLAB® ICD 2 In-Circuit Debugger, DV164004.Features
  • Motor control graphical user interface (MC-GUI)
  • Motor terminal strip
  • 3-phase voltage source inverter bridge
  • Motion sensor inputs
  • Over current protection, level programmable using potentiometer
  • Temperature sensor with I2C interface
  • Push button switches and master reset
  • 9 LEDs, 3 for generic status indication and 6 for PWM indication
  • Test points for motor current and back EMF sensing
  • Speed control potentiometer
  • Active RS-232 port
  • 24V external power supply (optional)
  • 3-phase, 24V BLDC low voltage motor (optional)
  • MPLAB ICD 2 connector
  • MPLAB ICE connector
  • Example software and documentation CDROM
下载连接:
PICDEM MC LV开发板用户指南
