3回答
0收藏
STM32多路ADC采集(DMA方式)
STMCU STMCU 8364 人阅读 | 3 人回复 | 2013-11-26
adc.h
  1. #ifndef __ADC_H
  2. #define        __ADC_H
  3. #include "stm32f10x.h"
  4. extern __IO uint16_t ADC_ConvertedValue[2];
  5. void ADC1_Init(void);
  6. #endif
adc.c
  1. #include "adc.h"
  2. #define ADC1_DR_Address    ((u32)0x40012400+0x4c)
  3. // __IO uint16_t ADC_ConvertedValue[4]={0x00};
  4. __IO uint16_t ADC_ConvertedValue[2]={0x00};
  5. //__IO u16 ADC_ConvertedValueLocal;
  6. /*
  7. * 函数名:ADC1_GPIO_Config
  8. * 描述  :使能ADC1和DMA1的时钟,初始化PC.01
  9. * 输入  : 无
  10. * 输出  :无
  11. * 调用  :内部调用
  12. */
  13. static void ADC1_GPIO_Config(void)
  14. {
  15.         GPIO_InitTypeDef GPIO_InitStructure;
  16.
  17.         /* Enable DMA clock */
  18.         RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
  19.
  20.         /* Enable ADC1 and GPIOC clock */
  21.         RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA, ENABLE);
  22.
  23.         /* Configure PC.01  as analog input */
  24. //         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6;
  25.         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_2;
  26.         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
  27.         GPIO_Init(GPIOA, &GPIO_InitStructure);                                // PA1,输入时不用设置速率
  28. }
  29. /* 函数名:ADC1_Mode_Config
  30. * 描述  :配置ADC1的工作模式为MDA模式
  31. * 输入  : 无
  32. * 输出  :无
  33. * 调用  :内部调用
  34. */
  35. static void ADC1_Mode_Config(void)
  36. {
  37.         DMA_InitTypeDef DMA_InitStructure;
  38.         ADC_InitTypeDef ADC_InitStructure;
  39.
  40.         /* DMA channel1 configuration */
  41.         DMA_DeInit(DMA1_Channel1);
  42.         DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;         //ADC地址
  43.         DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;//内存地址
  44.         DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  45. //         DMA_InitStructure.DMA_BufferSize = 4;
  46.         DMA_InitStructure.DMA_BufferSize = 2;
  47.         DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;//外设地址固定
  48.         DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;  //内存地址固定
  49.         DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;        //半字
  50.         DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  51.         DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;                //循环传输
  52.         DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  53.         DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  54.         DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  55.
  56.         /* Enable DMA channel1 */
  57.         DMA_Cmd(DMA1_Channel1, ENABLE);
  58.
  59.         /* ADC1 configuration */
  60.
  61.         ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;        //独立ADC模式
  62. //         ADC_InitStructure.ADC_ScanConvMode = ENABLE ;          //禁止扫描模式,扫描模式用于多通道采集
  63.         ADC_InitStructure.ADC_ScanConvMode = ENABLE ;          //禁止扫描模式,扫描模式用于多通道采集
  64.         ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;        //开启连续转换模式,即不停地进行ADC转换
  65.         ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;        //不使用外部触发转换
  66.         ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;         //采集数据右对齐
  67. //         ADC_InitStructure.ADC_NbrOfChannel = 4;                 //要转换的通道数目1
  68.         ADC_InitStructure.ADC_NbrOfChannel = 2;                 //要转换的通道数目1
  69.         ADC_Init(ADC1, &ADC_InitStructure);
  70.
  71.         /*配置ADC时钟,为PCLK2的8分频,即9Hz*/
  72.         RCC_ADCCLKConfig(RCC_PCLK2_Div8);
  73.         /*配置ADC1的通道11为55.        5个采样周期,序列为1 */
  74. //         ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 1, ADC_SampleTime_55Cycles5);
  75. //         ADC_RegularChannelConfig(ADC1, ADC_Channel_4, 2, ADC_SampleTime_55Cycles5);
  76. //         ADC_RegularChannelConfig(ADC1, ADC_Channel_5, 3, ADC_SampleTime_55Cycles5);
  77. //         ADC_RegularChannelConfig(ADC1, ADC_Channel_6, 4, ADC_SampleTime_55Cycles5);
  78.         ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_55Cycles5);
  79.         ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 2, ADC_SampleTime_55Cycles5);
  80.
  81.         /* Enable ADC1 DMA */
  82.         ADC_DMACmd(ADC1, ENABLE);
  83.
  84.         /* Enable ADC1 */
  85.         ADC_Cmd(ADC1, ENABLE);
  86.
  87.         /*复位校准寄存器 */
  88.         ADC_ResetCalibration(ADC1);
  89.         /*等待校准寄存器复位完成 */
  90.         while(ADC_GetResetCalibrationStatus(ADC1));
  91.
  92.         /* ADC校准 */
  93.         ADC_StartCalibration(ADC1);
  94.         /* 等待校准完成*/
  95.         while(ADC_GetCalibrationStatus(ADC1));
  96.
  97.         /* 由于没有采用外部触发,所以使用软件触发ADC转换 */
  98.         ADC_SoftwareStartConvCmd(ADC1, ENABLE);
  99. }
  100. /*
  101. * 函数名:ADC1_Init
  102. * 描述  :无
  103. * 输入  :无
  104. * 输出  :无
  105. * 调用  :外部调用
  106. */
  107. void ADC1_Init(void)
  108. {
  109.         ADC1_GPIO_Config();
  110.         ADC1_Mode_Config();
  111. }
回答|共 3 个
fj1161
发表于 2013-11-26 08:04:27 | 只看该作者
顶一个~~~~~~~~~~~~~~~~~~
第五年了,这次一定要坚持到底,不留遗憾!!!
iloveeeboard
发表于 2013-11-26 08:15:04 | 只看该作者
牛,大力支持
奋斗哥
发表于 2013-11-26 08:54:12 | 只看该作者
顶顶,必须顶!!!!!
